[gdal-dev] How to use JPEGXL in TIFF right?
thomas bonfort thomas.bonfort at gmail.com
Thu Oct 24 06:17:43 PDT 2024
Hi Jukka,
Yes, you should definitely be using tiled tiff with jxl. The actual tile
size (256,512 or 1024) did not seem to make much difference in file size
from what I have experienced, so you can choose that value depending on how
you plan to use the tifs later on.
In production use here, we use "-co BIGTIFF=YES -co TILED=YES -co
BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co COMPRESS=JXL -co JXL_EFFORT=3" .
Setting the effort to 3 greatly reduces compression time while having very
little effect on final image size on 16bit satellite imagery.
Regards,
TB
On Thu, Oct 24, 2024 at 1:00 PM Rahkonen Jukka via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> I made some tests about using JPEGXL (JXL) compression in GeoTIFF.  I am
> interested in lossless compression. So far I have learned that stripes are
> not good, but results from tiled TIFFs are promising.
> The GeoTIFF driver manual has a warning about WEBP compression: “There is
> a significant time penalty for each tile/strip with lossless WebP
> compression, so you may want to increase the BLOCKYSIZE value for strip
> layout.” I wonder if the same applies to JPEG XL compression as well.
> Without tiles this command was very slow
> gdal_translate -of gtiff -co compress=jxl p4433h.tif p4433h_jxl.tif
> This one was faster.
> gdal_translate -of gtiff -co tiled=yes -co compress=jxl p4433h.tif
> p4433h_jxl_tiled.tif
> Not only being slow but the compression with stripes does not really
> compress much. See the file sizes:
> With stripes:  359 211 087 p4433h_jxl.tif
> With 256x256 tiles:  142 188 540 p4433h_jxl_tiled.tif
> Referense (LZW): 283 864 896 p4433h_lzw.tif
> What might be the optimal block size for JXL-in-GeoTIFF when the aim is a
> good compression ratio and reasonable processing time?
> -Jukka Rahkonen-
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241024/81f75b50/attachment.htm>
