[gdal-dev] ogr2ogr for downloading extracts from overturemaps
Even Rouault even.rouault at spatialys.com
Thu Oct 24 13:39:09 PDT 2024
Le 24/10/2024 à 22:26, Varun Sharma via gdal-dev a écrit :
> Thanks Even for your prompt reply!
> 1. Just to clarify, with GDAL v3.10.0, the command
> ogr2ogr -f GPKG ogr_water.gpkg -spat 7.5 46.5 7.7 46.7
> /vsis3/overturemaps-us-west-2/release/2024-08-20.0/theme=base/type=water/
> is fine and I should see a ( significant ) speed up .. yes ?
Normally. but far from being instantaneous on my currently not super
fast Internet connection
You may try the gdal-master conda-forge channel to test right now:
https://gdal.org/en/latest/download.html#gdal-master-conda-builds
> 2. the apache arrow project libs itself have many knobs to tweak like
> threadpools, i/o threads, memory pools etc - are these exposed in GDAL
> configuration options ?
some are. See
https://github.com/OSGeo/gdal/blob/master/ogr/ogrsf_frmts/parquet/ogrparquetdatasetlayer.cpp#L505-L542
They should probably be mentioned in
https://gdal.org/en/latest/drivers/vector/parquet.html but I haven't
been brave enough to do that, not always fully understanding what they
actually do in libarrow/libparquet
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241024/c6d9a974/attachment-0001.htm>
