[gdal-dev] [EXTERNAL] Re: gdal.Rasterize with same OGR dataset from two python threads
Even Rouault
even.rouault at spatialys.com
Mon Oct 28 09:19:43 PDT 2024
Le 28/10/2024 à 17:15, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
APPLICATIONS INC] a écrit :
> How can I “open” a handle to a pre-existing memory dataset? That
> sounds like it may work for me.
If it is a dataset from the "Memory" driver, no. Otherwise you could for
example create a GeoPackage (or shapefile... if you don't want to hit
any SQLite locking) as a /vsimem/ file and open it as many times as wished.
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241028/7a6be1ba/attachment.htm>
