[gdal-dev] proj.db and other resource files when building with vcpkg
Thomas Sevaldrud
thomas at silentwings.no
Tue Oct 29 05:17:21 PDT 2024
Thank you Even, then I'll add some post-build magic.
Looking forward to Proj 9.6 then! :-D
- Thomas
On Tue, Oct 29, 2024 at 12:33 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Thomas,
> (that would be more a question for the proj-dev mailing list)
> quickly looking at the vcpkg PROJ recipe at
> https://github.com/microsoft/vcpkg/tree/master/ports/proj I don't see
> they do anything particular related to automated setting PROJ_DATA
> (PROJ_LIB is now a deprecated name), so you likely have to do it now .
> (conda-forge builds use a trick where upon installation the hard-coded
> path within the PROJ library is modified to match the location of your
> conda environment)
> The good news is that in PROJ 9.6, packagers will be able to build PROJ
> with proj.db embedded in the library, using the new capabilities offered
> by https://proj.org/en/latest/community/rfc/rfc-8.html
> Even
> Le 29/10/2024 à 12:25, Thomas Sevaldrud via gdal-dev a écrit :
> > Hi,
> > We are using gdal/proj through vcpkg, specifically the projections
> > framework with OGRSpatialReference, and everything builds nicely, but
> > when running our application we get errors related to missing proj.db.
> > Now, I understand that we can fix it by setting the PROJ_LIB
> > environment variable or copying files to a suitable path. What I am
> > wondering is if this shouldn't already be handled by CMake or VCPKG,
> > is there some step I am missing here?
> > The resource files can be found in the build directory under
> > "vcpkg_installed/[triplet]/share/proj" so I can do some post-build
> > stuff to copy files into the app output directory, but before I start
> > going that route I'd like to know if this is the way to do it. I would
> > guess that all users of the vcpkg gdal package will run into this issue?
> > Cheers,
> > Thomas
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end,
> this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241029/68848ba6/attachment.htm>
