[gdal-dev] Abou R sf library and GDAL
Roger Bivand Roger.Bivand at nhh.no
Tue Oct 29 07:20:58 PDT 2024
On Tue, 29 Oct 2024, Even Rouault wrote:
>> We'll try, but GDAL 3.9 needs to be more stable than 4 3.9 releases in
> five months suggests for it to be easy to ask for.
> 3.9.3 will be the the last in the 3.9 series, with whatever bugs it has.
Thanks! That'll be enough, I think; I just need to try the MXE build first
to be able to check that no extra upstream dependencies are brought in
than we already know about. The macOS static build is stuck at 3.5 as it
is still pre-Cmake; that may take more work.
Roger
> Even
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
