[gdal-dev] Abou R sf library and GDAL
Abel Pau
a.pau at creaf.cat
Wed Oct 30 01:25:10 PDT 2024
Thanks for the answer. I'll think about it.
-----Mensaje original-----
De: Andrew C Aitchison <andrew at aitchison.me.uk>
Enviado el: dimarts, 29 d'octubre de 2024 13:23
Para: Abel Pau <a.pau at creaf.cat>
CC: gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] Abou R sf library and GDAL
On Mon, 28 Oct 2024, Abel Pau via gdal-dev wrote:
> Hi Michael,
> Thank you for your response.
> I am working on a Windows 10 or 11 system (though I believe this
> detail is not particularly relevant). I am looking for the simplest
> method to install GDAL, as RStudio requires it as a dependency for the
> "sf" package.
> The question arises from a plain user (not developer) who works with R
> (I still need to confirm if they are using RStudio specifically) and
> wants to read MiraMon vector files directly, then save them back in
> the same format.
> Since this driver was added recently, I would like to understand how R
> users can employ "sf" to work with this format. Any guidance on making
> this setup accessible within the R environment would be greatly
> appreciated.
Would it be practical to take the MiraMon driver code and build it as a plugin against the installed GDAL (with devel libraries) ?
I don't know whether it would work, and it would need a local developer, but it is likley to be easier than rebuilding the whole of R with current GAL.
Andrew C. Aitchison Kendal, UK
