[gdal-dev] SQLite: create layer with wkbNone
Martin Landa
landa.martin at gmail.com
Wed Oct 30 04:46:10 PDT 2024
Hi all,
I have problem creating a new layer (no geometry) in SQLite data source:
from osgeo import ogr
driver_name = "SQLite"
filename = "test.db"
driver = ogr.GetDriverByName(driver_name)
with driver.CreateDataSource(filename) as ds:
layer = ds.CreateLayer("test", geom_type=ogr.wkbNone)
field = ogr.FieldDefn("label", ogr.OFTString)
layer.CreateField(field)
layer_defn = layer.GetLayerDefn()
feat = ogr.Feature(layer_defn)
feat.SetField("label", "test")
layer.CreateFeature(feat)
Created datasource doesn't contain any layer, no errors reported.
When I switch to GPKG driver, everything works fine:
ogrinfo test.gpkg test
OGRFeature(test):1
label (String) = test
I have GDAL: 3.9.2, do you have any idea what is wrong?
Thanks in advance for your help, best regards, Martin
Martin Landa
https://geomatics.fsv.cvut.cz/en/employees/martin-landa/
http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241030/83bf44c6/attachment-0001.htm>
