[gdal-dev] Abou R sf library and GDAL
Even Rouault
even.rouault at spatialys.com
Wed Oct 30 09:27:50 PDT 2024
Roger,
> Tomas also pointed to hot-fixes needed with 3.9.3 in pkg-config in
> that setting to remove ".lib" from "-lshell32.lib" and "-lole32.lib" -
> towards end of:
> https://svn.r-project.org/R-dev-web/trunk/WindowsBuilds/winutf8/ucrt3/toolchain_libs/mxe/src/gdal.mk
> If these file extensions as such are not needed in other settings,
> maybe they could be suppressed in the next RC?
Hopefully RC2 will be the last one, and that issue is far from being a
blocker. I've no idea where this shell32.lib or ole32.lib come from as
they are not referenced in GDAL sources themselves. Presumably from a
CMake/pkg-config from a GDAL dependency. Perhaps the fix should be in
that component that appends the .lib. Or maybe not. There's a lot of
dark magick in cmake/helpers/GdalGenerateConfig.cmake do deal with a
number of cases. Perhaps a new one is needed to strip out ".lib"
extension when "-l" is used....? I'm afraid only people with the
environment that triggers the issue are in a position to come with a
potential GDAL fix proposal.
> There are other patches too, most masking "int main(...)" in apps, and
> fine-tuning Cmake behaviour, and listed in
> https://svn.r-project.org/R-dev-web/trunk/WindowsBuilds/winutf8/ucrt3/toolchain_libs/mxe/src/gdal-1-fixes.patch
> and needing intervention at each upgrade.
Some of them (but perhaps not all) might potentially be considered for
upstream inclusion. Part of them won't be necessary in master since
we've started to drop a few of the unused utilities. Up to the people
annoyed by maintaining them to submit pull requests to GDAL. One per
topic. Some of the CMake changes (thinking of the PostgreSQL ones)
should also likely be submitted directly to
.https://gitlab.kitware.com/cmake/cmake from which a number of the
FindXXXX.cmake files come from.
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
