[gdal-dev] WMTS request error
Michał Kowalczuk michkowalczuk at gmail.com
Tue Sep 3 05:15:47 PDT 2024
Thank you, I will test it.
It's a pity that the WMTS documentation doesn't mention it.
The WMTS docs indicates that only 3 options are available for WMTS:
GDAL_MAX_CONNECTIONS, GDAL_ENABLE_WMS_CACHE, GDAL_DEFAULT_WMS_CACHE_PATH (
https://gdal.org/en/latest/drivers/raster/wmts.html#configuration-options).
I guess I still don't have enough experience in navigating the
documentation and using GDAL;-)
Michał Kowalczuk
wt., 3 wrz 2024 o 11:31 Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
napisał(a):
> Hi,
> I would read https://gdal.org/en/latest/user/configoptions.html and try
> there 3:
> GDAL_HTTP_MAX_RETRY=value: Defaults to 0. Set the number of HTTP attempts,
> when a retry is allowed. (cf GDAL_HTTP_RETRY_CODES for conditions where a
> retry is attempted.) The default value is 0, meaning no retry.
> GDAL_HTTP_RETRY_DELAY=<seconds>: Defaults to 30. Set the delay between
> HTTP attempts.
> GDAL_HTTP_RETRY_CODES=ALL or comma-separated list of codes: (GDAL >= 3.10)
> Specify which HTTP error codes should trigger a retry attempt. Valid values
> are ALL or a comma-separated list of HTTP codes. By default, 429, 500, 502,
> 503 or 504 HTTP errors are considered, as well as other situations with a
> particular HTTP or Curl error message.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Michal
> Kowalczuk via gdal-dev
> *Lähetetty:* tiistai 3. syyskuuta 2024 12.08
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] WMTS request error
> Dear GDAL colleagues,
> Does GDAL has any http request failure detection, and mechanism for
> dealing with it different than raising CPL Error.
> Look at the following GDAL log. (Problem explanation after the log)
> *[Tue Sep  3 10:54:47 2024].7930, 1227.3430: HTTP: Requesting [1/10]
> https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=1
> <https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=1>
> [Tue Sep  3 10:54:47 2024].7930, 1227.3430: HTTP: Requesting [2/10]
> https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=2
> <https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=2>
> [Tue Sep  3 10:54:49 2024].3630, 1228.9130: HTTP: Requesting [3/10]
> https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=3
> <https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=3>
> [Tue Sep  3 10:54:50 2024].3630, 1229.9130: HTTP: Requesting [4/10]
> https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=4
> <https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=4>
> [Tue Sep  3 10:54:50 2024].9300, 1230.4800: HTTP: Requesting [5/10]
> https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=5
> <https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=5>
> [Tue Sep  3 10:54:52 2024].5640, 1232.1140: HTTP: Requesting [6/10]
> https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=6
> <https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=6>
> [Tue Sep  3 10:54:52 2024].7680, 1232.3180: HTTP: Requesting [7/10]
> https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=7
> <https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=7>
> [Tue Sep  3 10:54:53 2024].1190, 1232.6690: HTTP: Requesting [8/10]
> https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=8
> <https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=8>
> [Tue Sep  3 10:54:53 2024].6050, 1233.1550: HTTP: Requesting [9/10]
> https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=9
> <https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=9>
> [Tue Sep  3 10:54:53 2024].9630, 1233.5130: HTTP: Requesting [10/10]
> https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=10
> <https://mapy.geoportal.gov.pl/wss/service/PZGIK/ORTO/WMTS/StandardResolution?service=WMTS&request=GetTile&version=1.0.0&layer=ORTOFOTOMAPA&style=default&format=image/jpeg&TileMatrixSet=EPSG:4326&TileMatrix=EPSG:4326:5&TileRow=4&TileCol=10>
> [Tue Sep  3 10:54:54 2024].3000, 1233.8500: HTTP: Request [0]
> : status = 0, type = (null), error = (null) [Tue Sep  3 10:54:54
> 2024].3000, 1233.8500: HTTP: Request [1]
> : status = 200, type = image/jpeg, error = (null) [Tue Sep  3 10:54:54
> 2024].3000, 1233.8500: HTTP: Request [2]
> 2024].3000, 1233.8500: HTTP: Request [3]
> 2024].3000, 1233.8500: HTTP: Request [4]
> 2024].3000, 1233.8500: HTTP: Request [5]
> 2024].3000, 1233.8500: HTTP: Request [6]
> 2024].3000, 1233.8500: HTTP: Request [7]
> 2024].3000, 1233.8500: HTTP: Request [8]
> 2024].3000, 1233.8500: HTTP: Request [9]
> 2024].3030, 1233.8530: WMS: ReadBlockFromCache [Tue Sep  3 10:54:54
> 2024].3040, 1233.8540: CPLError:
> C:\Users\Michal\.cache\gdalwmscache\d03651177815877cffe0faf894690352/0/6/069e88521499910bd8763ede3e0cc2c4:
> No such file or directory ERROR 4:
> No such file or directory [Tue Sep  3 10:54:54 2024].3040, 1233.8540:
> CPLError: GDALWMS: Unable to open downloaded block. ERROR 1: GDALWMS:
> Unable to open downloaded block. [Tue Sep  3 10:54:54 2024].3040,
> 1233.8540: WMS: After ReadBlockFromCache [Tue Sep  3 10:54:54 2024].3040,
> 1233.8540: CPLError: GDALWMS: Unable to download block 1, 4. URL:   HTTP
> status code: 0, error: (null). Add the HTTP status code to
> <ZeroBlockHttpCodes> to ignore this error (see
> http://www.gdal.org/frmt_wms.html <http://www.gdal.org/frmt_wms.html>).
> ERROR 1: GDALWMS: Unable to download block 1, 4. URL:   HTTP status code:
> 0, error: (null). Add the HTTP status code to <ZeroBlockHttpCodes> to
> ignore this error (see http://www.gdal.org/frmt_wms.html
> <http://www.gdal.org/frmt_wms.html>). [Tue Sep  3 10:54:54 2024].3050,
> 1233.8550: CPLError: GDAL_WMS>, band 3: IReadBlock failed at X offset 1, Y
> offset 4: GDALWMS: Unable to download block 1, 4. URL:   HTTP status code:
> <http://www.gdal.org/frmt_wms.html>). ERROR 1: GDAL_WMS>, band 3:
> IReadBlock failed at X offset 1, Y offset 4: GDALWMS: Unable to download
> block 1, 4. URL:   HTTP status code: 0, error: (null). Add the HTTP status
> code to <ZeroBlockHttpCodes> to ignore this error (see
> http://www.gdal.org/frmt_wms.html <http://www.gdal.org/frmt_wms.html>).*
> I use GDALRasterIO from C API and as we can see GDAL makes 10 requests.
> One of these request (*bolded*) ends with error, which generates the
> "Unable to open downloaded block." error later.
> Is there any method to force a *re-request* in such situations?
> This server error occurs randomly and temporarily, and the next attempt
> completes without problem.
> Regards,
> Michał
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240903/531a0442/attachment-0001.htm>
