[gdal-dev] Driver order for HDF5 versus netCDF
Even Rouault
even.rouault at spatialys.com
Thu Sep 5 13:22:39 PDT 2024
Kurt,
> Looking at the expected behavior at GDAL's head, I see this. I think
> it's probably fine, but figured I'd ask...
I don't reproduce with master:
$ gdalinfo autotest/gdrivers/data/hdf5/metadata.h5
Driver: HDF5/Hierarchical Data Format Release 5
$ gdalinfo autotest/gdrivers/data/hdf5/u8be.h5
Driver: HDF5Image/HDF5 Dataset
> Is there a reason for the order to be different for the drivers in the
> DEFERRED section compared to the normal driver registration? Does the
> order not matter for DEFERRED?
No, that doesn't matter since drivers are re-ordered using the order
defined in frmts/drivers.ini
But in the netCDF vs HDF5 case, this doesn't matter much since the logic
in netCDFIdentifyFormat() will skip a HDF5 file if "#ifdef HAVE_HDF5" is
true and GDALGetDriverByName("HDF5") != nullptr
My guess would be that your build of the netCDF driver lacks -DHAVE_HDF5
. By the way I'm thinking this check might be incorrect. This HAVE_HDF5
is if libnetcdf has HDF5 support, but in the context of the check if
GDALGetDriverByName("HDF5") != nullptr, we don't actually care about the
capabilities of libnetcdf. It is just that if the HDF5 driver is there,
we should just use it.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240905/d4512aff/attachment.htm>
