[gdal-dev] Call for review on RFC 101: Raster dataset read-only thread-safety
Even Rouault
even.rouault at spatialys.com
Fri Sep 6 15:34:59 PDT 2024
Frank,
> I'm actually surprised that it is considered impractical to make
> some/most drivers thread safe (read-only) natively and I thought key
> ones already were mostly there in the past though I'm not so confident
> in my memory.
Things have got more sophisticated over time with more deferred loading
strategies, but I don't think any driver has been close to be
thread-safe even in read-only scenarios. Except maybe the RasterIO part
of the RawDataset, which has pretty much no mutable state (if you
exclude file operations, and anything involving the block cache)
> Looking through the GTiff code I find myself not able to work out
> where locking is done and how we are managing the directory
> loading/switching as block reads are done.
No locking is done. To be noted that the logic of TIFF directory
loading/switching changed "a few" years ago. In the previous situation,
the main dataset and its overview datasets were sharing the same TIFF*
handle. But that strategy of switching from TIFF directory when
switching between overview datasets had also a major performance
drawback of invalidating TIFF bytecount[] and offset[] arrays, which was
particularly annoying when computing overviews, where that back&forth is
done consistently. And that inconvenience increased with the size of
datasets and those arrays. But even if there are now several TIFF*
handles, they do share the same VSILFILE* underneath, and there's a
layer between the driver and libtiff to ensure that the file pointer
position is properly set when activating one TIFF* handle at the
position it expected, that flushes are done propertly so that one TIFF*
handle does see a consistent state on disk (for read/write scenarios), etc.
> I would certainly like to work towards read-only thread safety for
> some drivers with:
> - a shared block cache for all threads reading from a dataset
That easiest way of doing that would be to put a per-dataset mutex in
classes GDALHashSetBandBlockCache and GDALArrayBandBlockCache, but that
would hurt scalability even when several threads try to access different
blocks at the same time (unless smart things are done to drop the mutex
as soon as possible)
> - no duplication of file handles per-thread
I just don't see how to do that. Even a mutex around file operations
would not be sufficient since we'd want both Seek()+Read() to be atomic
per thread. PRead() would solve that, but very few drivers or underlying
libraries use PRead() (and there's no implementation of it for all file
systems, like Windows file API which lacks it). Or one would need a
VSIThreadSafeHandle that would maintain a per-thread position, but that
would still involves locking around access to the underneath handle.
libtiff itself has a lot of state variables, in its core or in its
codecs (e.g. the deflate codec has to maintain a zlib handle as a state
variable if doing partial reads of a tile/strip). Even getting the
location of a TIFF tile is not thread-safe when defered
byteount[]/offset[] array loading is enabled (which is necessary when
dealing with extremely large remote COGs) since it involves file accesses.
You could raise the point that the GTiff driver does have multi-threaded
read optimizations, but it takes a lot of precautions to make that
happening safely, and it has the chance of fully controlling the
conditions where that happens. So basically it starts by fetching the
location and size of the needed blocks, then each thread will read the
needed blocks (either using PRead() if available, or taking a mutex
around file accesses), create per-thread TIFF* handle, replicating the
strategic TIFF tags from the main TIFF handle so that the codecs are
initialized with the appropriate state and using a new
TIFFReadFromUserBuffer() call that was added in libtiff to decode an
in-memory encoded buffer (without doing file accesses). And even with
that, I remember having fixed last year or so a case that I totally
missed initially, where the block cache accidentally triggered in one of
those worker thread. So yes, multi-threading is hard to get right.
> - a way of checking that a dataset is considered to be thread safe.
Not totally sure to understand what you mean here. The RFC introduces a
IsThreadSafe() virtual method that a driver can potentially implement
(only set to true currently by instances of GDALThreadSafeDataset). But
finding if a driver is thread-safe seems to be a non-solvable/provable
problem to me, apart from staring at the code for a sufficient long time
to convince oneself it is actually + adding some torture tests and hope
they catch most issues. But things can get very complicated if you need
to test all combinations of virtual methods that can be called...
> I'm curious if you can talk a bit more about the challenges of
> accomplishing the above. I had been hoping to take advantage of my
> (assumption) that this already mostly existed in GDAL for our new high
> performance environment at Planet so it is of more than academic
> interest to me.
Probably that implementing a restricted read-only thread-safe TIFF
driver, only addressing the common cases of TIFF without all the edge
cases GDAL and libtiff try to address, for a controlled set of codecs,
assuming pread() is always available, assuming you always read full
tiles & strips, re-implementing a very simplified libtiff, and doing it
"at hand" would be workable. Perhaps also excluding raster queries not
at a resolution that exactly matches one of the overview level to
completely by-pass the block cache. But that would be a separate driver,
with a more restricted set of functionality than our current GDAL
GeoTIFF driver that handles all the possible cases.
> Also, doesn't gdalwarp's multithreading support already depend on
> read-only thread safety for source files?
Definitely not. The initial -multi mode works with 2 threads: one for
I/O, one for compute. The later was further extended to also
multi-thread the compute part. But I/O is still done by a single thread,
hence no requirement on the thread-safety of drivers.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240907/7e9e17af/attachment-0001.htm>
