[gdal-dev] RANGE Requests on large Rasters with CDN (AWS Cloudfront)
Sean Turner sean.turner at koboldmetals.com
Mon Sep 9 07:06:33 PDT 2024
Hi all,
Curious if anyone is doing something similar.
We've got our data in an S3 Bucket that is fronted by Cloudfront. From
there we can use the GDAL `GDAL_HTTP_HEADER_FILE` environment variable to
point to a file containing Cloudfront signed cookies (which control access
to files within Cloudfront).
Cloudfront supports a maximum file size of 50gb. Trying to add a raster
layer that is greater than 50gb immediately results in an error.
Is anyone doing something similar and have a work around? AWS Documentation
mentions RANGE requests where a range of incremental 50gb are requested
from Cloudfront and downloaded simultaneously. Is this supported by GDAL
(QGIS)?
Otherwise also considering using a VRT?
https://gdal.org/en/latest/drivers/raster/vrt.html
Open to any and all suggestions!
Cheers. Also, sorry I haven't done one of these mailing lists before,
apologies if this submission is in the wrong place.
All the best,
Sean
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240909/8778524f/attachment.htm>
