[gdal-dev] Is there a FACE Conformant version of GDAL and its DTED drivers?
Ethan Payne Ethan.Payne at parrylabs.com
Mon Sep 9 09:23:10 PDT 2024
I'm currently assisting with a project that involves using DTED files to analyze terrain and elevation. As this project adheres to the FACE Technical Standard and must meet FACE Conformance requirements, I wanted to inquire whether there is a version of GDAL configured to comply with the FACE Technical Standard.
Any guidance or recommendations you can provide would be greatly appreciated. Thank you for your time.
Best Regards,
Ethan Payne
The information contained in this e-mail and any attachments from Parry Labs may contain confidential and/or proprietary information, and is intended only for the named recipient to whom it was originally addressed. If you are not the intended recipient, any disclosure, distribution, or copying of this e-mail or its attachments is strictly prohibited.   If you have received this e-mail in error, please notify the sender immediately by return e-mail and permanently delete the e-mail and any attachments.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240909/c7f7d02c/attachment.htm>
