[gdal-dev] Upgrade or remove Java JDK 17 in GDAL Docker image
Even Rouault even.rouault at spatialys.com
Mon Sep 9 10:56:12 PDT 2024
Matt,
Several potential solutions:
1) Regenerate the Docker image from sources:
git clone https://github.com/OSGeo/gdal
cd gdal
./docker/ubuntu-full/build.sh
2) Same as 1), but before edit ./docker/ubuntu-full/Dockerfile to remove
all traces of java/jdk from it
3) Use the existing image, remove the openjdk package, and "flatten" the
Docker layers with docker export / docker import (cf
https://forums.docker.com/t/how-to-flatten-an-image-with-127-parents/1600/2),
so that the layer where it was installed disappears
4) Wait a couple hours while I'm regenerating it to be updated to
17.0.12+7-1ubuntu2~24.04
Even
Le 09/09/2024 à 19:29, Matt Luck - NOAA Affiliate via gdal-dev a écrit :
> Hi, our IT department has detected a security vulnerability in the
> Java JDK version 17 that's installed in the ubuntu-full docker image
> (see message below). I am able to remove the Java files from the
> Docker image via the Dockerfile and I've tried changing the
> `JAVA_VERSION` in the Dockerfile, but there always seems to be a
> reference remaining in the Docker diff files that I can't seem to get
> rid of.
> To reproduce:
> A `docker system prune -a -f`, then `sudo find
> /var/lib/docker/overlay2 -type d -name java-17-openjdk-amd64` finds
> nothing, but then `docker pull ghcr.io/osgeo/gdal:ubuntu-full-3.9.1`
> followed by `sudo find /var/lib/docker/overlay2 -type d -name
> java-17-openjdk-amd64` finds:
> /var/lib/docker/overlay2/1d5a9f2712fb9b28bfa857509a45fb334005cda0ea58fea8a259af8eb3fcb2db/diff/usr/lib/jvm/java-17-openjdk-amd64
> /var/lib/docker/overlay2/1d5a9f2712fb9b28bfa857509a45fb334005cda0ea58fea8a259af8eb3fcb2db/diff/usr/lib/debug/usr/lib/jvm/java-17-openjdk-amd64
> /var/lib/docker/overlay2/1d5a9f2712fb9b28bfa857509a45fb334005cda0ea58fea8a259af8eb3fcb2db/diff/usr/share/gdb/auto-load/usr/lib/jvm/java-17-openjdk-amd64
> Because they're diff files, those files exist whether or not they're
> actually in the container and thus the vulnerability is always
> triggered. Is there a solution and/or a way to either upgrade the Java
> version or remove Java entirely if it's not needed so that we can deal
> with this issue in the future?
> On Mon, Jul 8, 2024 at 10:21 AM X wrote:
>     All,
>     Please see the vulns below and remediate as soon as possible.
>     These are in containers.
>     Path              :
>     /var/lib/docker/overlay2/48c2e3da9fc2282822d4522e28ca46788f5357a14a8a38f687e2cadbf9de68d7/diff/usr/lib/jvm/java-17-openjdk-amd64/
>       Installed version : 17.0.8
>       Fixed version     : Upgrade to a version greater than 17.0.10
>     Path              :
>     /var/lib/docker/overlay2/4aed72b0f0433c615afe67854c8c79bb7acca2fb01216bf6be25774180266f4d/diff/usr/lib/jvm/java-17-openjdk-amd64/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240909/007682b2/attachment.htm>
