[gdal-dev] [EXTERNAL] s3 request example
Mayer, David P
dpmayer at usgs.gov
Mon Sep 9 14:49:17 PDT 2024
Would ~200 GB be large enough?
Here is a mosaic of a section of Mars at 6 meters/pixel in a public S3 bucket:
s3://asc-pds-services/mosaic/Mars/Mars_MRO_CTX_Equi_Mosaics_Robbins/6mpp/MC16_6mpp.16bit.tif
Cheers,
David
David Mayer
Geographer
Astrogeology Science Center
US Geological Survey
dpmayer at usgs.gov
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Javier Jimenez Shaw via gdal-dev <gdal-dev at lists.osgeo.org>
Sent: Monday, September 9, 2024 13:55
To: gdal dev <gdal-dev at lists.osgeo.org>
Subject: [EXTERNAL] [gdal-dev] s3 request example
This email has been received from outside of DOI - Use caution before clicking on links, opening attachments, or responding.
Hi
I am experiencing a much slower load of a remote COG using vsis3 with the QGIS from conda than the QGIS in my Ubuntu (that uses GDAL 3.4.1).
Because both are QGIS 3.38, I think the problem is in the version of GDAL.
I would like to research it more.
Is there any example of a (big) COG file in Amazon S3 I can use to compare them? Unfortunately the credentials for the files I am using expire after a few hours, so they are useless to report anything.
Best regards,
Javier
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240909/aa86e3fd/attachment.htm>
