[gdal-dev] Upgrading to GDAL 3.4.2 from 1.10.0 shows different outputs from gdaltransform and corresponding C++ API
Even Rouault even.rouault at spatialys.com
Mon Sep 9 18:12:32 PDT 2024
Le 10/09/2024 à 02:55, Fox, Shawn D (US) via gdal-dev a écrit :
> Evan,
> Thanks for putting some time into that response and showing some examples.  Perhaps I should clarify exactly how our software is using GDAL.  I thought that it was easier to show the problem using gdaltransform rather than source code, but that does lack some context.  Here is crude, but simple example of how the C Apis are being used.
> --- source code begin ---
> OGRSpatialReferenceH sourceSRS = OSRNewSpatialReference(NULL);
> OGRSpatialReferenceH targetSRS = OSRNewSpatialReference(NULL);
> errorSource = OSRSetWellKnownGeogCS( sourceSRS, "NAD27");
> errorTarget = OSRSetWellKnownGeogCS( targetSRS, "WGS84");
> OGRCoordinateTransformationH ptrCT = OCTNewCoordinateTransformation( sourceSRS, targetSRS );
> status = OCTTransform( ptrCT, 1, x_lon, y_lat, NULL );
Source code speaks for itself :-) This is a CRS axis order issue. Cf
https://gdal.org/en/latest/tutorials/osr_api_tut.html#crs-and-axis-order
for the whole discussion
With your current code and GDAL >= 3, the input axis order should be
(lat, lon) since NAD27 in EPSG is declared as (lat, lon) ordered and
GDAL 3 honours that by default
If you want to keep long, lat axis order, add
OSRSetAxisMappingStrategy(errorSource, OAMS_TRADITIONAL_GIS_ORDER); and
OSRSetAxisMappingStrategy(errorTarget, OAMS_TRADITIONAL_GIS_ORDER);
before creating the coordinate transformation
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240910/eb7d2bba/attachment.htm>
