[gdal-dev] Ignore content-length in vsicurl?
Daniel Evans daniel.fred.evans at gmail.com
Tue Sep 10 07:30:42 PDT 2024
Hi Jukka,
It seems your documentation search skills are better than mine! That does
the trick.
Cheers,
Daniel
On Tue, 10 Sept 2024 at 15:10, Rahkonen Jukka <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> Have you tried with configuration option “CPL_VSIL_CURL_USE_HEAD=[YES/NO]:
> Defaults to YES. Controls whether to use a HEAD request when opening a
> remote URL.”
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Daniel
> Evans via gdal-dev
> *Lähetetty:* tiistai 10. syyskuuta 2024 16.57
> *Vastaanottaja:* 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org) <
> gdal-dev at lists.osgeo.org>
> *Aihe:* [gdal-dev] Ignore content-length in vsicurl?
> Hi all,
> I am attempting to read a dataset via /vsicurl/ where I believe the server
> is incorrectly returning `content-length: 0` in response to HEAD requests.
> This causes GDAL to believe it's a zero-length file, and it therefore can't
> be read.
> If I download the file via HTTP GET, it's valid, and GDAL can read it
> locally. I've also confirmed I can use /vsicurl/ on some test datasets in
> the GDAL repo.
> Is it possible to force GDAL to work around the faulty content-length
> header, or is it too fundamental a problem to ignore?
> I've separately got in touch with the data provider to see if they are
> able to fix the issue at their end.
> Cheers,
> Daniel
> URL of the troublesome dataset:
> https://data.source.coop/earthgenome/sentinel2-temporal-mosaics/20NMH_2024-04-01_2024-08-01/B08.tif
> Example HTTP header responses I'm seeing:
> GET
> HTTP/2 200
> date: Tue, 10 Sep 2024 13:47:54 GMT
> content-type: binary/octet-stream
> content-length: 278198294
> vary: Origin, Access-Control-Request-Method, Access-Control-Request-Headers
> etag: "a79f3f685281d6681e4d362536c5b3eb-34"
> last-modified: Thu, 25 Jul 2024 13:16:08 GMT
> x-version: 0.0.16
> access-control-allow-credentials: true
> HEAD
> HTTP/2 200
> date: Tue, 10 Sep 2024 13:48:08 GMT
> content-length: 0
> x-version: 0.0.16
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240910/8e863583/attachment.htm>
