[gdal-dev] Motion: approve RFC 101 "Raster dataset read-only thread-safety"
Even Rouault
even.rouault at spatialys.com
Wed Sep 11 12:26:41 PDT 2024
I move to approve RFC 101 "Raster dataset read-only thread-safety":
https://github.com/OSGeo/gdal/pull/10676
Starting with my +1,
The candidate implementation is available in
https://github.com/OSGeo/gdal/pull/10746. While fine tuning it, I
realized there were subtleties, related to the fact we use thread-local
datasets under the hood, for methods returning a non-"primitive" type,
such as a "const char*" whose lifetime is tied to a dataset/band. If
we'd get it from a thread-local dataset, and that one would be later
evicted from the cache (not very common, but could happen if one would
open tons of thread-safe datasets at the same time), then you could have
use-after-free issues. For such methods (GetMetadata(),
GetMetadataItem(), GetProjectionRef(), etc. as well as GetColorTable()
which returns a GDALColorTable pointer, or GetSpatialRef() which returns
a OGRSpatialReference*), I've preferred to protect their access with a
mutex around the "prototype" dataset passed when constructing
GDALMultiThreadedDataset, whose lifetime is at least as long as
GDALMultiThreadedDataset (cf commit
https://github.com/OSGeo/gdal/pull/10746/commits/849e9cea711efd30c47fd90a7a6b71a75611c1a5#diff-687008dd6e3d5ac8ad05568272746ed75b84de50bde508f78f2d79a6842825c7L428)
. Normally such methods aren't called in user code repeatedly, so there
should be any noticeable lock contention in practice. The main objective
of the RFC which is to be able to issue RasterIO() requests in parallel
isn't affected by that. Ah, and one thing I realized is that
OGRSpatialReference isn't thread-safe, so I've also added an optional
SetThreadSafe() on it, to also use a per-instance mutex in
multi-threaded scenarios (cf commit
https://github.com/OSGeo/gdal/pull/10746/commits/c7e1862273dd018e58a01f25b21fdff6dbfdd1cd).
Multi-threading is hard...
Even
http://www.spatialys.com
