[gdal-dev] [EXTERNAL] s3 request example
Even Rouault even.rouault at spatialys.com
Fri Sep 13 10:49:53 PDT 2024
Le 13/09/2024 à 19:40, Javier Jimenez Shaw a écrit :
> Thanks Even
> regarding GDAL_SKIP=TileDB as environment variable, it still shows the
> message
> [Fri Sep 13 19:37:03 2024].8370, 10.5869: GDAL: On-demand registering
> /home/jshaw/anaconda3/envs/qgis_stable/lib/gdalplugins/gdal_TileDB.so
> using GDALRegister_TileDB.
Ah... I forgot that QGIS overrides it. In QGIS, go to Settings / Option
/ Data Sources / GDAL and uncheck TileDB in the driver list (you may
need to uncheck it in both the Raster and Vector tab)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240913/8326bae4/attachment.htm>
