[gdal-dev] (TileDB related question for you Norman/Sean) Re: [EXTERNAL] s3 request example
Even Rouault even.rouault at spatialys.com
Fri Sep 13 15:44:31 PDT 2024
Norman confirmed that a URI to a TileDB dataset can only be a directory,
so we can tighten the identification check:
https://github.com/OSGeo/gdal/pull/10798
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240914/7a603c21/attachment-0001.htm>
