[gdal-dev] Call to GDALDestroy results in occasional core dump, GDAL 3.4.2
    Even Rouault
    even.rouault at spatialys.com
    Wed Sep 18 09:35:52 PDT 2024
Le 18/09/2024 à 18:27, Fox, Shawn D (US) via gdal-dev a écrit :
> Could someone help me understand this sentence from the documentation
> at gdal.h: Raster C API — GDAL documentation
> <https://gdal.org/en/latest/api/raster_c_api.html> for the GDALDestroy
> function?
> “Since GDAL 2.4.0, this function may be called by application code,
> since it is no longer called automatically, on non-MSVC builds, due to
> ordering problems with respect to automatic destruction of global C++
> objects.”
> What are the ordering problems and why might it be called due to
> ordering problems?  The statement does state some kind of difference
> between MSVC and non-MSVC builds. The sentence doesn’t clearly state
> to me whether I should or shouldn’t call that function to cleanup. The
> language in the documentation is ambiguous, and it is not clear to me
> how important it is to call this method.  Cleaning up seems like a
> good idea but I could simply free the memory via delete for any object
> that is returned instead of calling GDALDestroy.
You don't necessarily have to call GDALDestroy(). It reclaims various
static objects allocated by GDAL. Basically it helps for "valgrind
--leak-check=full" use cases.
The issue that caused it to no longer be registered as a GCC destructor
function is that if you have for example a static GDALDataset object, it
was found that GDALDestroy() was called before the destruction of the
GDALDataset object, which lead to double-free. Cf commit comment of
https://github.com/OSGeo/gdal/commit/e8c9bea5dbe8e90d01d575f94a040fcaee27c24f
> On a RHEL8 build, which is non-MSVC, I am observing segmentation
> faults.  The errors vary from one execution of the program to another.
Hard to tell the reason. Show the code, use Valgrind.
Check also with ldd that your executable isn't linked to 2 different
versions of libproj. The error message you mention is typical of that
situation
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240918/7c9aa5aa/attachment.htm>
