[gdal-dev] Removing Trac wiki content
Edouard Choinière
e.chs at outlook.com
Fri Sep 20 08:09:56 PDT 2024
If you think some things are valuable enough to be kept in the internet archive, you can give them a heads up before removing the site completely. Otherwise, there’s also a way to have a Google sheets with all links to save and have them all saved again one last time to help out.
Edouard Choinière
Le 19 sept. 2024 à 18:28, Norman Barker <norman.barker at gmail.com> a écrit :
Thanks Even, I didn't realize that.
On Thu, Sep 19, 2024 at 5:26 PM Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>> wrote:
Le 20/09/2024 à 00:25, Norman Barker via gdal-dev a écrit :
+1 The old RFCs were useful but as you can get them from the wayback machine that is fine.
They are all at https://gdal.org/en/latest/development/rfc/index.html too, aren't they?
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240920/03c6b6f2/attachment.htm>
