[gdal-dev] Field type detection by GeoJSON driver in the case of untidy data
Even Rouault even.rouault at spatialys.com
Mon Sep 23 09:35:21 PDT 2024
Sean,
yes if there's a mix of data types, a String(JSON) field is reported to
mean that.
The only annoying thing is that for backward compatibility with past
behaviour where we silently homogenized to a string, we didn't go to the
point to actually quoting strings, so this isn't fully JSON compliant
unfortunately
I mean if we have out.json with:
"type": "FeatureCollection",
"features": [
{ "type": "Feature", "properties": { "foo": "str" }, "geometry": null },
{ "type": "Feature", "properties": { "foo": 0 }, "geometry": null },
{ "type": "Feature", "properties": { "foo": ["a", "b"] }, "geometry": null }
$ ogrinfo -al out.geojson -q
Layer name: out
OGRFeature(out):0
   foo (String(JSON)) = str
OGRFeature(out):1
   foo (String(JSON)) = 0
OGRFeature(out):2
   foo (String(JSON)) = [ "a", "b" ]
In theory, we should report "str", not just str. A GDAL 4.0 topic... ?
Just recorded it in
https://github.com/OSGeo/gdal/issues/8440#issuecomment-2368801316
To actually answer your last question, this is a bit more subtle than
the above. For example, if there's a mix of strings and array of
strings, we report a StringList field. If there's a mix of integer and
floating-point numbers, we report a Real field (which is OK since JSON
has just a "numeric" type)
Even
Le 23/09/2024 à 18:17, Sean Gillies via gdal-dev a écrit :
> Hi all,
> The good thing about GeoJSON is that you don't need specialized GIS
> software to create it. The bad thing about GeoJSON is that people
> create it using software with none of the familiar GIS constraints.
> I've been looking at a collection of features that have the same set
> of properties (good), but one of the properties has a mix of strings
> (strings of digits, specifically) and unquoted numbers (0,
> specifically). In versions <= 3.5, GDAL detects this field's type to
> be "String". In versions >= 3.6, the field type is "String(JSON)". Is
> this intended behavior? Will all such fields be found to be
> "String(JSON)", or does it depend on their content?
> Sean Gillies
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240923/0d604548/attachment.htm>
