[gdal-dev] "libertiff" (was Re: Call for review on RFC 101: Raster dataset read-only thread-safety)
Even Rouault
even.rouault at spatialys.com
Tue Sep 24 09:22:37 PDT 2024
Somewhat related to some of the discussions in that thread, to be able
to read "uncommon" (to remain polite) GeoTIFF products generated by the
Sentinel Application Toolbox (https://github.com/OSGeo/gdal/pull/10867),
I found that using libtiff, libgeotiff or the GDAL GTiff driver wasn't
going to be practical, so I wrote my own TIFF library, dubbed
"libertiff": https://github.com/libertiff/libertiff
C++11, no variable argument brain damage like in libtiff, header only,
read-only, no codec support for now (no actual pixel reading capability
in fact, just telling you the offset&size of tiles&strips. yes, that's a
big limitation :-)), thread-safe by design.
Fits in 1,500 lines of code or so:
https://github.com/libertiff/libertiff/blob/master/libertiff.hpp. Could
maybe serve as a foundation for a potential future thread-safe read-only
GDAL GeoTIFF driver.
Even
Le 06/09/2024 à 21:57, Frank Warmerdam a écrit :
> Even,
> I'm actually surprised that it is considered impractical to make
> some/most drivers thread safe (read-only) natively and I thought key
> ones already were mostly there in the past though I'm not so confident
> in my memory. Looking through the GTiff code I find myself not able
> to work out where locking is done and how we are managing the
> directory loading/switching as block reads are done.
> I would certainly like to work towards read-only thread safety for
> some drivers with:
> - a shared block cache for all threads reading from a dataset
> - no duplication of file handles per-thread
> - a way of checking that a dataset is considered to be thread safe.
> I'm curious if you can talk a bit more about the challenges of
> accomplishing the above. I had been hoping to take advantage of my
> (assumption) that this already mostly existed in GDAL for our new high
> performance environment at Planet so it is of more than academic
> interest to me. Also, doesn't gdalwarp's multithreading support
> already depend on read-only thread safety for source files?
> The above said, I can also see some utility in RFC 101 and have no
> objection to it.
> Best regards,
> Frank
> On Fri, Sep 6, 2024 at 12:45 PM Kurt Schwehr via gdal-dev
> <gdal-dev at lists.osgeo.org> wrote:
> My take would be to not offer the force option unless there is
> someone who states they really need it.
> On Fri, Sep 6, 2024 at 6:52 AM Even Rouault via gdal-dev
> Hi,
> No other reactions? In particular w.r.t. the open question
> whether it is
> worth to offer a "force" mode in the situations where a
> dataset cannot
> be re-opened (or for a band whose belonging to a dataset
> cannot be
> determined) where the thread-safe wrapper would just put a
> mutex around
> the calls to that dataset/band (so obviously this wouldn't
> scale with
> the number of threads). I'm probably leaning on not offering
> this option
> for now, if there's no obvious need it is useful. It can
> always been
> added afterwards.
> Even
> Le 29/08/2024 à 14:26, Even Rouault via gdal-dev a écrit :
> > Hi,
> > I've worked on a new RFC 101: Raster dataset read-only
> thread-safety:
> > https://github.com/OSGeo/gdal/pull/10676
> > Summary: This RFC enables users to get instances of
> GDALDataset (and
> > their related objects such as GDALRasterBand) that are
> thread-safe for
> > read-only raster operations, that is such instances can be
> safely used
> > from multiple threads without locking.
> > It is backed by a preliminary implementation (fairly
> complete, apart
> > from writing new tests...). There's at least one open
> question raised
> > in the RFC.
> > PS: you can see one of the benefits of the migration of the
> doc to
> > ReadTheDocs hosting, with the preview of the updated
> documentation in
> > pull requests. So this is a way to mention that the move to RtD
> > hosting has now been completed, with the default version
> ("latest")
> > reflecting the state of the master branch, as well as the
> version for
> > the release/3.9 branch. Thanks to Dan Baston (and other people
> > involved) for this work! There might be a few adjustments
> needed, so
> > if you notice something unusual w.r.t. to the previous
> state, please
> > file a ticket.
> > Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | USA: +1 650-701-7823
> and watch the world go round - Rush | CAN: +1 343-550-9984
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240924/842d9a62/attachment-0001.htm>
