[gdal-dev] GDAL CSharp bindings maintainers/contributors listening... ?
Even Rouault
even.rouault at spatialys.com
Fri Sep 27 11:15:31 PDT 2024
This is your regular remainder that nobody in the core GDAL maintainer
team is a CSharp aficionado (we don't have a personal grief against it,
just that we are blatantly ignorant, at least speaking for myself !), so
related tickets about it will definitely result in no action.
See
https://github.com/OSGeo/gdal/issues?q=is%3Aissue+is%3Aopen+label%3A%22csharp+bindings%22
The current trend is that people seem to be annoyed by UTF-8 related
issues. The issue is likely that our methods that accept or take a const
char* in the SWIG bindings should use a specific typemap to map to
CSharp Unicode strings instead of the "C" one or whatever those concepts
are called in CSharp. There is an existing "utf8_path" typemap that is
used in method that accept filenames, that should probably be renamed to
utf8_string and be used more extensively. And probably with a version of
the methods to also return a raw C string / bytearray in the cases where
drivers don't know the encoding and might return "random" stuff. Cf pull
request #10652 where I did something for Java that suffered from that
later issue.
Happy pull requests!
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240927/abda79b4/attachment.htm>
