[gdal-dev] GPKG geometry column name expectations with sqlite dialect
Even Rouault
even.rouault at spatialys.com
Mon Sep 30 11:57:27 PDT 2024
Jesse,
Le 30/09/2024 à 20:35, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
APPLICATIONS INC] via gdal-dev a écrit :
> Hi,
> I have two geopackage database files that were constructed, somehow,
> in a way that one has a geometry column called ‘geometry’ and the
> other ‘geom’. QGIS nor OGR seem to have much an issue with this.
> Both handle / display all the features in the expected ways. However,
> for the gpkg with the ‘geom’ column name (which I believe is
> irregular), the usual SQLisms (with dialect=sqlite) seem to fail. For
> the former gpkg, I can use the GEOMETRY identifier as documented
> successfully, however, this fails with the latter with an ‘no such
> column: GEOMETRY’ error. The documentation leads me to believe that
> that identifier _/should/_ resolve to whatever the geometry column
> name is,
Hum, that was an unfortunate copy&paste from the OGR SQL dialect... Will
be fixed per https://github.com/OSGeo/gdal/pull/10900
> and maybe it does internally but then something later goes haywire for
> opaque reasons.
Only for OGR SQL, not for the SQLite native SQL as used by GPKG. For the
later you need to use exactly the geometry column name of the table.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240930/d4ccc234/attachment.htm>
