[gdal-dev] Fwd: Performance Variability with GDAL Caching and Multi-Threading for MODIS Data
Varisht Ghedia
varisht at tathya.earth
Tue Apr 1 00:19:30 PDT 2025
Dear GDAL Developers,
I am working on optimizing the processing times for MODIS datasets (LST_1Km
and QC Day tile) using pymodis with some modifications. Specifically, I
have added flags for:
Running on all available CPU cores (ALL_CORES)
Adjusting GDAL cache size (GDAL_CACHEMAX)
However, I am observing unexpected performance variations. In some cases,
increasing the cache size degrades performance instead of improving it.
Below are my test results for two different datasets from the same tile.
Tile used: MOD11A1.A2025073.h10v10.061.2025074095514.hdf
EPSG:32618, Resampled to 30m
*QC_tile.tif*
ALL_CORES + 2G
real 0m24.199s
user 0m53.352s
sys 0m9.998s
STANDARD RUN (No Cache, No Multi-Threading)
real 0m32.133s
user 0m30.581s
sys 0m2.299s
ALL_CORES + 512M
real 0m13.830s
user 0m51.083s
sys 0m1.911s
With 512M cache, performance improves significantly, but with larger caches
(1G, 2G, 4G), execution time increases.
*LST_Day_1km.tif*
ALL_CORES + 512M
real 0m42.863s
user 0m44.105s
sys 0m3.583s
real 0m45.121s
user 0m26.477s
sys 0m3.712s
ALL_CORES + 2G
real 0m37.548s
user 0m48.302s
sys 0m8.113s
ALL_CORES + 4G
real 0m51.845s
user 0m48.213s
sys 0m7.988s
For this dataset, using a 2G cache improves performance, but increasing it
to 4G makes processing slower.
*Questions:*
1.
How does GDAL’s caching mechanism impact performance in these scenarios?
2.
Why does increasing cache size sometimes degrade performance?
3.
Is there a recommended way to tune cache settings for MODIS HDF
processing, considering that some layers (like QC) behave differently from
others (like LST_1Km)?
Any insights into how GDAL handles multi-threading and caching internally
would be greatly appreciated.
Thanks in advance for your help!
Best regards,
Varisht Ghedia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250401/4b0b268d/attachment-0001.htm>
