[gdal-dev] writing parquet to /vsiaz/ fails when chunked
Even Rouault
even.rouault at spatialys.com
Fri Apr 4 14:52:31 PDT 2025
Le 04/04/2025 à 20:40, Simon Norris via gdal-dev a écrit :
> Perhaps another hapless user question:
> Using ogr2ogr, I can write very small parquet files to /vsiaz/<container>/<file>.parquet without issue.
> But with larger files (that ogr2ogr tries to write in chunks), Azure does not accept the first PUT request and ogr2ogr fails with:
Can't reproduce with a dataset of mine. Maybe this is specific to your
input dataset ?
> I'd file an issue but if it was a bug I'd think it would have already have been found by other users?
ah ah, if everybody had the same thinking, nobody would report bugs ;-)
> thanks
> Simon
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250404/e53d9384/attachment.htm>
