[gdal-dev] writing parquet to /vsiaz/ fails when chunked
snorris at hillcrestgeo.ca snorris at hillcrestgeo.ca
Sat Apr 5 08:25:28 PDT 2025
Thanks Even.
I didn't scroll down far enough in the google results - this blogger had the same symptoms.
https://dzone.com/articles/azure-blob-storage-specified
> On Apr 5, 2025, at 4:12 AM, Even Rouault <even.rouault at spatialys.com> wrote:
> The error is:
> URL_INFO_HEADER_OUT: PUT /bcfishpass/crossings.parquet?se=2025-04-05T05%3A19Z&sp=rwdl&sv=2022-11-02&sr=c&skoid=d80366e6-b960-4aad-b22e-879eb27768e8&sktid=8b76c303-01ec-40d5-8d9a-6c2f6d78dcd7&skt=2025-04-05T04%3A19%3A14Z&ske=2025-04-05T05%3A19%3A00Z&sks=b&skv=2022-11-02&sig=kZTkJQ0%2BCS6%2Btm9S/jCjyZ5U4C51%2BJwO9bHNvG19EgU%3D HTTP/1.1
> Host: cabdbcfishpassstorage.blob.core.windows.net
> User-Agent: GDAL/3.10.2
> Accept: */*
> Content-Length: 0
> x-ms-blob-type: AppendBlob
> x-ms-date: Sat, 05 Apr 2025 04:19:18 GMT
> CURL_INFO_TEXT: Request completely sent off
> CURL_INFO_HEADER_IN: HTTP/1.1 409 The blob type is invalid for this operation.
> Googling for this error message leads to a number of issues where the naming of the file seems to be involved. This is quite mysterious. In any case using the same exact command line as yours (that is I created a bfishpass container) works fine for me. But I don't use shared access signature. Maybe that's the difference...
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250405/9fa3537d/attachment.htm>
