[gdal-dev] Performance Issue with VRT Pixel Function and Large Number of Source Rasters
Laurențiu Nicola
lnicola at dend.ro
Mon Apr 14 00:55:47 PDT 2025
Hi Abdul,
Can you bump https://gdal.org/en/stable/user/configoptions.html#config-GDAL_MAX_DATASET_POOL_SIZE and see if it helps? And do all inputs have the same block size of 1048x7? Ideally, your inputs and output will all have the same block size or a multiple of it, so you could also add -co BLOCKXSIZE=1048 -co BLOCKYSIZE=7.
Note that these should apply just as well when you don't have a pixel function, so it's probably not it.
https://github.com/OSGeo/gdal/pull/11850 might also help in the future, but you'll need to change your workflow for it.
Laurentiu
On Mon, Apr 14, 2025, at 07:52, Abdul Raheem Siddiqui via gdal-dev wrote:
> Dear GDAL Community,
> I am encountering a performance issue when using a VRT consisting of a large number of source rasters and built-in C++ pixel function ("max"). I would appreciate any guidance on whether some GDAL config option can improve this, or I am doing something wrong, or this is a potential optimization opportunity.
> I have A VRT file referencing ~750 individual rasters (Byte data type, avg size ~1000x1000 pixels, untiled, and same CRS for all source rasters). The VRT uses the built-in “max” pixel function.
> Running gdal_translate to convert the VRT to GTiff takes ~1.5 hours and consumes ~4GB RAM.
> gdal_translate -of GTiff merged.vrt OUTPUT.tif
> When tripling the number of source rasters (to ~2250) by duplicating entries in the VRT, processing time increases to ~4.5 hours, with RAM usage rising to ~11.5GB.
> gdal_translate -of GTiff merged_3x.vrt OUTPUT.tif
> Extracting a small subset of the VRT via -projwin does not improve performance (still slow, ~14GB RAM used).
> gdal_translate -projwin -146955.241 797044.4497 -138766.1444 789656.0648 -of GTiff merged_3x.vrt OUTPUT.tif
> *Removing the pixel function makes processing instantaneous, even with 2250 rasters.*
> Performance is unaffected by --config GDAL_CACHEMAX or -co NUM_THREADS=ALL_CPUS.
> The issue persists across other datasets that I have. In fact, it gets really worse when source rasters are relatively larger or of Float32 data type.
> Gdalinfo on one of the source rasters: https://pastebin.com/gjHDA2Wd
> *Data:* https://drive.google.com/file/d/1LGlzGGZvkPyXvKKgkPVzQGbBw55p5dRd/view?
> System: Windows, 8 CPUs, 32GB RAM (GDAL 3.9.2 via OSGeo4W).
> Thank you for your time and insights. Please reply if you are aware of how performance can be improved.
> Regards,
> *Abdul Siddiqui, PE*
> _abdul.siddiqui at ertcorp.com_
> *ERT | *Earth Resources Technology, Inc.
> 14401 Sweitzer Ln. Ste 300
> Laurel, MD 20707
> https://www.ertcorp.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250414/df21b767/attachment.htm>
