[gdal-dev] Performance Issue with VRT Pixel Function and Large Number of Source Rasters
Even Rouault
even.rouault at spatialys.com
Mon Apr 14 06:45:20 PDT 2025
Abdul,
if you add <SkipNonContributingSources>true</SkipNonContributingSources>
as a child element of the <VRTRasterBand> element, and apply patch
https://github.com/OSGeo/gdal/commit/3dbc60b334ee022f2993dca476b08d5fed01698c
, "gdal_translate -of GTiff merged.vrt OUTPUT.tif" completes in a few
minutes
Cf
https://gdal.org/en/stable/drivers/raster/vrt.html#using-derived-bands-with-pixel-functions-in-python
for the doc of SkipNonContributingSources
Even
Le 14/04/2025 à 06:52, Abdul Raheem Siddiqui via gdal-dev a écrit :
> Dear GDAL Community,
> I am encountering a performance issue when using a VRT consisting of a
> large number of source rasters and built-in C++ pixel function
> ("max"). I would appreciate any guidance on whether some GDAL config
> option can improve this, or I am doing something wrong, or this is a
> potential optimization opportunity.
> I have A VRT file referencing ~750 individual rasters (Byte data type,
> avg size ~1000x1000 pixels, untiled, and same CRS for all source
> rasters). The VRT uses the built-in “max” pixel function.
> Running gdal_translate to convert the VRT to GTiff takes ~1.5 hours
> and consumes ~4GB RAM.
> When tripling the number of source rasters (to ~2250) by duplicating
> entries in the VRT, processing time increases to ~4.5 hours, with RAM
> usage rising to ~11.5GB.
> gdal_translate -of GTiff merged_3x.vrt OUTPUT.tif
> Extracting a small subset of the VRT via -projwin does not improve
> performance (still slow, ~14GB RAM used).
> gdal_translate -projwin -146955.241 797044.4497 -138766.1444
> 789656.0648 -of GTiff merged_3x.vrt OUTPUT.tif
> *Removing the pixel function makes processing instantaneous, even with
> 2250 rasters.*
> Performance is unaffected by --config GDAL_CACHEMAX or -co
> NUM_THREADS=ALL_CPUS.
> The issue persists across other datasets that I have. In fact, it gets
> really worse when source rasters are relatively larger or of Float32
> data type.
> Gdalinfo on one of the source rasters: https://pastebin.com/gjHDA2Wd
> *Data:*
> https://drive.google.com/file/d/1LGlzGGZvkPyXvKKgkPVzQGbBw55p5dRd/view?
> System: Windows, 8 CPUs, 32GB RAM (GDAL 3.9.2 via OSGeo4W).
> Thank you for your time and insights. Please reply if you are aware of
> how performance can be improved.
> Regards,
> *Abdul Siddiqui, PE*
> _abdul.siddiqui at ertcorp.com_
> *ERT | *Earth Resources Technology, Inc.
> 14401 Sweitzer Ln. Ste 300
> Laurel, MD 20707
> https://www.ertcorp.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250414/22883c71/attachment-0001.htm>
