[gdal-dev] Performance Issue with VRT Pixel Function and Large Number of Source Rasters
Abdul Raheem Siddiqui abdulraheemsiddiqui at gmail.com
Fri Apr 18 19:58:49 PDT 2025
Pull request here: https://github.com/OSGeo/gdal/pull/12178 There is
potentially more subelements that can go in this top level section but I
was not sure if they would work across all types of pixel functions.
P.S: Is there a reason why SkipNonContributingSources is False by default?
Wouldn't it make more sense to have it set to True by default?
Abdul
On Wed, Apr 16, 2025 at 6:09 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Thanks for the quick fix Even! *My only remaining concern is that the
> documentation lists SkipNonContributingSources under Python Pixel
> Functions, even though it applies to both C++ and Python Pixel Functions.
> Shouldn't it be elevated to be mentioned more generically under Derived
> Band?*
> Indeed. A pull request updating that would be welcome
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250418/1db43e09/attachment.htm>
