[gdal-dev] gdal 3.11 vector pipeline with postgres problems
Richard Greenwood
richard.greenwood at gmail.com
Sat Apr 26 11:14:06 PDT 2025
Below works:
*$ gdal vector info PG:"$PGCONN" -l "roads"*
And this works:
*$ gdal vector convert PG:"$PGCONN" -l "roads" junk*
But below fails (I'm using pipeline because I need an intermediate step
once I get this to work). I do not have the postgis_raster extension in
this database.
*$ gdal vector pipeline read PG:"$PGCONN" -l "roads" ! write junkERROR 1:
Error browsing database for PostGIS Raster tables: ERROR 1: Error browsing
database for PostGIS Raster tables: Usage: gdal vector pipeline [OPTIONS]
<PIPELINE>Try 'gdal vector pipeline --help' for help.*
I created the postgis_raster extension and ran the same pipeline:
read: Cannot find source layer 'roads'*
It seems like requiring the postgis_raster extension is a bug.
What about the *Cannot find source layer*? I fiddled with specifying the
schema, different quoting, etc.
Thanks
Richard W. Greenwood
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250426/59d65c92/attachment.htm>
