[gdal-dev] gdal 3.11 -dsco vs --co
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Tue Apr 29 23:22:23 PDT 2025
Your syntax with the "gdal" frontend is correct. This command is accepted:
gdal vector convert -f MVT --co NAME=foo in.shp out
The reason for the error may be in the commas in the value of the TILING_SCHEME. The same error message can be triggered with
gdal vector convert -f MVT --co NAME="foo,bar" in.shp out
The uncommon creation option value makes probably confusion due to this mechanism https://gdal.org/en/latest/development/rfc/rfc104_gdal_cli.html#repeated-values-multi-valued-options
The new front-end is announced to be unstable and experimental because of this kind of issues. Thank you for finding out one.
-Jukka Rahkonen-
________________________________________
Lähettäjä: gdal-dev käyttäjän Richard Greenwood via gdal-dev puolesta
Lähetetty: Keskiviikko 30. huhtikuuta 2025 5.52
Vastaanottaja: GDAL List
Aihe: [gdal-dev] gdal 3.11 -dsco vs --co
In the docs at 'latest'https://gdal.org/en/latest/drivers/vector/mvt.html#dataset-creation-optionsit seems like -dsco needs to be --co for the new 'gdal' front-end cli but still -dsco for the the old 'ogr2ogr'. Am I correct or am I overlooking something?I am also getting an error with 'gdal vector pipeline write' when I use: --co TILING_SCHEME="EPSG:3738,1622000,1284700,686000"ERROR 1: write: Invalid value for argument 'creation-option'. <KEY>=<VALUE> expectedThanks-- Richard W. Greenwood
