[gdal-dev] gdal vector concat fails with `Too many open files` but ogrmerge works fine
Even Rouault even.rouault at spatialys.com
Mon Aug 4 06:06:02 PDT 2025
Robin,
this was an oversight of the implementation of gdal vector concat. Fixed
per https://github.com/OSGeo/gdal/pull/12856
Apart from using ogrmerge, a workaround is to increate the limit of open
files with "ulimit -n some_number"
Even
Le 04/08/2025 à 13:19, Robin Wilson via gdal-dev a écrit :
> Hi,
> I’ve just started experimenting with the new gdal command line tools.
> I’ve tried the following command to merge a few thousand GeoJSON files
> into one GeoPackage:
> gdal vector concat --mode=single gb-postcodes-v5/units/*.geojson
> all_unit_postcodes.gpkg
> I get thousands of errors like:
> ERROR 4: gb-postcodes-v5/units/KY4.geojson: Too many open files
> Switching back to ogrmerge, I find that this command works fine:
> ogrmerge -single -progress -o all_unit_postcodes_v2.gpkg
> Has there been a change which means that gdal vector concat tries to
> open all the files in parallel, and then runs out of spare file
> handles? Is there any way around this for the new gdal vector concat
> command?
> Best regards,
> Robin
> Dr Robin Wilson
> www.rtwilson.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250804/3565c982/attachment.htm>
