[gdal-dev] argument default value in the C API to GDALAlgorithmArg
Even Rouault even.rouault at spatialys.com
Thu Aug 7 01:56:26 PDT 2025
Chris,
why would you need it to be exposed ? If it is to workaround missing C
API entry points, we should add them
Regarding struct GDALAlgorithmHS being exposed in gdalalgorithm.h, this
is because another GDAL .cpp file needed it, but I think I should create
instead a gdalalgorithm_priv.h header to move those struct definitions.
Please don't rely on the internals of struct GDALAlgorithmHS
Even
Le 07/08/2025 à 06:44, Chris Toney a écrit :
> Hi Even,
>> If you need this in 3.11, you can define the following implementation
>> detail in your code
>> struct GDALAlgorithmArgHS
> Could GDALAlgorithmArgHS be defined in gdalalgorithm.h (as struct
> GDALAlgorithmHS is)?
> Chris
> On Mon, Aug 4, 2025 at 2:42 AM Even Rouault <even.rouault at spatialys.com> wrote:
>> Hi Chris,
>> This was indeed missing in the C API. Queued for 3.12 in
>> https://github.com/OSGeo/gdal/pull/12853
>> detail in your code
>>       GDALAlgorithmArg *ptr = nullptr;
>>       explicit GDALAlgorithmArgHS(GDALAlgorithmArg *arg) : ptr(arg)
>> but better conditionalize it to 3.11 only, so that to avoid issues in
>> later version if we would change the definition of struct GDALAlgorithmArgHS
>> and then do things like
>> GDALAlgorithmArgH hArg;
>> hArg->ptr->GetDefault<std::string>();
>> Even
>> Le 04/08/2025 à 03:46, Chris Toney via gdal-dev a écrit :
>>> Hi,
>>> In the C API there is GDALAlgorithmArgHasDefaultValue(), but no
>>> interface to the GetDefault() class method to access the value itself
>>> when there is one (nor in the Python bindings, AFAICS).
>>> I don't believe there is a fromHandle() method on GDALAlgorithmArg to
>>> get to the C++ object.
>>> Is there possibly a workaround for that when working through the C API?
>>> Chris
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> http://www.spatialys.com
>> My software is free, but my time generally not.
