[gdal-dev] pipeline algorithm from C API
Even Rouault
even.rouault at spatialys.com
Tue Aug 19 01:34:01 PDT 2025
Chris,
> I don't see a way in the C API to obtain the pipeline algorithm step
> registry or access the step algorithms to obtain their argument
> properties and values. Would GetStepAlg() and related methods
> potentially be exposed in the C API at some point, along with a
> "GetStepRegistry"?
That could be an option. Another already existing one is to use
GDALAlgorithmGetUsageAsJSON() on the pipeline algorithm. You'll get the
step algorithms and their arguments under the "pipeline_algorithms" key.
Please file a ticket if you prefer the C API.
> When run as described above, the main pipeline (actual) algorithm
> object has an output arg of type DATASET, but it is not explicitly set
> and has null value even though the file output is successfully
> generated. I assume the dataset object is available in the output arg
> of the "write" step algorithm, but I haven't followed that code
> closely enough to understand some details. If that is correct though,
> could the final output dataset be propagated up to the main pipeline
> algorithm "output" arg?
I suspect a mis-use of the API, because that definitely works as shown
by the following Python snippet (which uses the C API)
>>> from osgeo import gdal
>>> alg = gdal.Run('raster pipeline', pipeline='read
autotest/gcore/data/byte.tif ! write /vsimem/out.tif')
>>> print(alg.Output().GetDescription())
/vsimem/out.tif
Maybe you run GDALAlgorithmFinalize() ? If so then the output dataset
gets closed and the output dataset arg is nullified.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250819/21eae53f/attachment.htm>
