[gdal-dev] VSIReadDirRecursive is O(n^2) with large nested hierarchies
Even Rouault
even.rouault at spatialys.com
Tue Aug 19 02:59:42 PDT 2025
Hi Craig,
your option (1) sounds good to me. However, there is no requirement that
all file entries in a directory are consecutive, so the raw entry list
could potentially be
dirA/file1
dirB/file1
dirA/file2
dirB/file2
depending on how files are inserted in the ZIP. So you likely need to
sort things before creating your index.
Even
Le 19/08/2025 à 07:26, Craig de Stigter via gdal-dev a écrit :
> Hi folks
> I've stumbled across VSIReadDirRecursive being really slow when I give
> it a ridiculously large ZIP file (containing 5 million files across
> ~1500 subdirectories)
> I spent a while poking round the source code. It looks like
> VSIArchiveFilesystemHandler::ReadDirEx() performs repeated linear
> scans through the flat VSIArchiveContent::entries array during
> recursive directory traversal. For each directory level, it scans all
> entries from the beginning, resulting in O(n²) time complexity.
> Performance degrades from ~1.3s for the first 5,000 files to ~6.7s for
> 5000 files once I get 100K files into a 5-million-file ZIP archive,
> and keeps getting worse from there. I haven't managed to list the
> whole 5M-file archive yet...
> A couple of possible solutions:
> 1. Add a directory index to VSIArchiveContent (add a map of string
> directory paths to index in the entries array) so we can jumpstart the
> ReadDirEx implementation at the right place
> 2. make a VSIDIRArchive class (subclass of VSIDIR) and override
> OpenDir/NextDirEntry, so that it doens't call ReadDirEx repeatedly but
> instead just returns entries from the VSIArchiveContent::entries array.
> I'm leaning towards (1) because it would presumably improve random
> lookups by file path also (not just ReadDirRecursive). Is this
> something that would be accepted as a PR?
> Thanks
> Regards,
> Craig
> Platform Engineer
> Koordinates
> koordinates.com <http://koordinates.com/> / @koordinates
> <https://twitter.com/koordinates>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250819/c144e286/attachment.htm>
