[gdal-dev] Problems generating a COG file
Even Rouault
even.rouault at spatialys.com
Wed Aug 20 11:31:42 PDT 2025
Javier,
- which GDAL version it is ?
- the "corrupted double-linked list" is definitely a proof of either a
bug, or a mis-configuration. This is a message we see sometimes when
GDAL accidentally links against 2 different libproj. Can you check "ldd
/path/to/libgdal.so" to see if there is not 2 libproj appearing ?
- can you reproduce the issue with a fully blank file with the same
characterists. For example try "gdal_create -if web_mercator.tif
web_mercator_blank.tif -co SPARSE_OK=YES -co TILED=YES", and then run
the gdal_translate to COG on that web_mercator_blank.tif
- does running in single threaded mode with GDAL_NUM_THREADS=1 make a
difference regarding the error messages?
Even
Le 20/08/2025 à 19:17, Javier Jimenez Shaw via gdal-dev a écrit :
> Hi
> I am warping a file to EPSG:3857 and later generating a COG with JPEG
> compression.
> The input tif file has also JPEG compression. (I learned that I need
> the -dstalpha to keep it transparent)
> I am doing it in Ubuntu 22.04 using conda.
> First I tried this, using LZW as output of the warp
> GDAL_CACHEMAX=16GB GDAL_NUM_THREADS=ALL_CPUS gdalwarp -t_srs EPSG:3857
> -ct "+proj=pipeline +step +inv +proj=tmerc +lat_0=49 +lon_0=-2
> +k=0.9996012717 +x_0=400000 +y_0=-100000 +ellps=airy +step +proj=push
> +v_3 +step +proj=cart +ellps=airy +step +proj=helmert +x=446.448
> +y=-125.157 +z=542.06 +rx=0.15 +ry=0.247 +rz=0.842 +s=-20.489
> +convention=position_vector +step +inv +proj=cart +ellps=WGS84 +step
> +proj=pop +v_3 +step +proj=webmerc +lat_0=0 +lon_0=0 +x_0=0 +y_0=0
> +ellps=WGS84" -co COMPRESS=LZW -co BIGTIFF=YES -co TILED=YES -dstalpha
> orthomosaic.tiff web_mercator.tif
> Creating output file that is 677881P x 303664L.
> Processing orthomosaic.tiff [1/1] :
> 0...10...20...30...40...50...60...70...80...90...100 - done in 00:27:04.
> then I try to generate the COG
> GDAL_CACHEMAX=16GB GDAL_NUM_THREADS=ALL_CPUS gdal_translate
> web_mercator.tif web_mercator_cog.tif -co COMPRESS=JPEG -co
> BIGTIFF=YES -of COG
> Input file size is 677881, 303664
> 0ERROR 1: LZWDecode:Not enough data at scanline 0 (short 40448 bytes)
> 0. - estimated
> remaining time: 00:14:34
> and failed
> As it is an LZW problem, I tried with DEFLATE:
> +ellps=WGS84" -co COMPRESS=DEFLATE -co BIGTIFF=YES -co TILED=YES
> -dstalpha orthomosaic.tiff web_mercator_d.tif
> 0...10...20...30...40...50...60...70...80...90...100 - done in 00:27:34.
> And then the same
> web_mercator_d.tif web_mercator_cog.tif -co COMPRESS=JPEG -co
> BIGTIFF=YES -of COG
> 0.. - estimated
> remaining time: 02:29:49ERROR 1: ZIPDecode:Decoding error at scanline 0
> 0...10... - estimated remaining time:
> 00:42:12
> and failed :(
> Trying again I got this output at a similar point (but nothing about
> ZIPDecode:Decoding error at scanline 0).
> Aborted (core dumped)
> What can it be? Is there any workaround?
> The file is big in pixels, but a big part is transparent.
> web_mercator_d.tif is "only" 14GB
> Thank you.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250820/90b52e4a/attachment.htm>
