[gdal-dev] Problems generating a COG file
Even Rouault
even.rouault at spatialys.com
Wed Aug 20 15:00:34 PDT 2025
Hum, it would be useful if you could subset the input file to the
minimum needed to reproduce the error and (possibly privately) share it
to me.
Even
Le 20/08/2025 à 23:36, Javier Jimenez Shaw a écrit :
> Right. it fails
> $ gdal_translate web_mercator.tif web_mercator_jpeg.tif -co
> COMPRESS=JPEG -co BIGTIFF=YES -of GTIFF -co TILED=YES -co
> BLOCKXSIZE=512 -co BLOCKYSIZE=512 -oo NUM_THREADS=ALL_CPUS
> Input file size is 677881, 303664
> 0.. - estimated remaining time:
> 00:31:20ERROR 1: LZWDecode:Not enough data at scanline 0 (short 2 bytes)
> But if I change -oo with -co, it fails somewhere else:
> $ gdal_translate web_mercator.tif web_mercator_jpeg_co.tif -co
> BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co NUM_THREADS=ALL_CPUS
> 0...10... - estimated
> remaining time: 00:10:55ERROR 1: web_mercator.tif:Using code not yet
> in table
> ERROR 1: TIFFReadEncodedTile() failed.
> ERROR 1: web_mercator.tif, band 1: IReadBlock failed at X offset 2570,
> Y offset 216: TIFFReadEncodedTile() failed.
> On Wed, 20 Aug 2025 at 22:43, Even Rouault
> <even.rouault at spatialys.com> wrote:
>> Can I do other useful tests tonight?
> Maybe just check/confirm that the issue is multithreading on the
> decoding side (which it looks to be) with:
> where web_mercator.tif is LZW or Deflate compressed
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250821/fd184275/attachment.htm>
