[gdal-dev] How to compare closed curves with different start points?
George Mathijssen
george.mathijssen at gmail.com
Mon Aug 25 01:13:49 PDT 2025
The geometry is indeed a plate with rounded corners and 2 circular holes,
it is an actual geometry in the port of Rotterdam though I have simplified
it somewhat.
The differences between the 2 geometries is that the exterior ring has
different start points and the right most inner ring has different start
points. The leftmost inner ring is identical between the two geometries. My
intention was to also include different ring directions, but I forgot to do
that.
Visualizing the st_difference query that you ran shows differences in the
right most ring. It is not the entire ring that is different, just parts of
it. I think this has to do with rounding and the fact that the curve
segments are actually different: the start point in the second geometry is
one point over, which means that the circular strings are entirely
different.
Compare this to the exterior ring: I choose a different start point, but I
did not actually change the curve segments. So the result is that all curve
segments are identical, but in a different order. This might explain why
st_difference detects the exterior rings as being identical. I wonder if
this changes when I make the direction of the exterior rings opposite of
each other.
On Sat, 23 Aug 2025 at 19:56, Rahkonen Jukka <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> I thought that PostGIS would return an empty geometry with ST_Difference,
> but it does not. I do not know what that means. Maybe PostGIS is
> linearizing the curve before computing the difference. Your geometry seems
> to be like a plate with rounded corners and two holes, and I guess that the
> ring of the rightmost hole is oriented differently.
> This was my query:
> select st_difference(
> 'CURVEPOLYGON (COMPOUNDCURVE (CIRCULARSTRING (85369.63 433446.48, 85368.99
> 433448.54, 85366.08 433449.62), (85366.08 433449.62, 85320.0 433442.34),
> CIRCULARSTRING (85320.0 433442.34, 85318.48 433441.52, 85317.85 433439.94),
> (85317.85 433439.94, 85323.26 433407.01), CIRCULARSTRING (85323.26
> 433407.01, 85324.24 433405.814, 85325.76 433405.24), (85325.76 433405.24,
> 85371.68 433412.51), CIRCULARSTRING (85371.68 433412.51, 85373.66
> 433413.74, 85374.28 433415.25), (85374.28 433415.25, 85369.63 433446.48)),
> CIRCULARSTRING (85361.39 433438.49, 85365.44 433434.44, 85361.39 433430.39,
> 85357.34 433434.44, 85361.39 433438.49), CIRCULARSTRING (85327.69 433426.1,
> 85330.18 433423.61, 85327.69 433421.12, 85325.2 433423.61, 85327.69
> 433426.1))
> ','CURVEPOLYGON (COMPOUNDCURVE (CIRCULARSTRING (85320.0 433442.34,
> 85318.48 433441.52, 85317.85 433439.94), (85317.85 433439.94, 85323.26
> 433407.01), CIRCULARSTRING (85323.26 433407.01, 85324.24 433405.814,
> 85325.76 433405.24), (85325.76 433405.24, 85371.68 433412.51),
> CIRCULARSTRING (85371.68 433412.51, 85373.66 433413.74, 85374.28
> 433415.25), (85374.28 433415.25, 85369.63 433446.48), CIRCULARSTRING
> (85369.63 433446.48, 85368.99 433448.54, 85366.08 433449.62), (85366.08
> 433449.62, 85320.0 433442.34)), CIRCULARSTRING (85357.34 433434.44,
> 85361.39 433438.49, 85365.44 433434.44, 85361.39 433430.39, 85357.34
> 433434.44), CIRCULARSTRING (85327.69 433426.1, 85330.18 433423.61, 85327.69
> 433421.12, 85325.2 433423.61, 85327.69 433426.1))');
> -Jukka Rahkonen-
> ________________________________________
> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> käyttäjän George
> Mathijssen via gdal-dev <gdal-dev at lists.osgeo.org> puolesta
> Lähetetty: Lauantai 23. elokuuta 2025 17.29
> Vastaanottaja: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> Aihe: [gdal-dev] How to compare closed curves with different start points?
> Hi,In an application that I am currently developing there is a need to
> compare geometries and I hit an obstacle when comparing
> OGRCurvePolygons.From a SQL/MM perspective I (mostly) need
> ST_OrderingEquals, meaning that the coordinates must be in the same order.
> This is implemented by OGRCurvePolygon as is stated in the
> documentation.The obstacle however is that there are 3 freedoms when
> comparing polygons:* the direction of a ring may differ* the start point of
> a ring may differ* the order of inner rings may differFor example the
> following 2 curve polygons should be considered equal in the application
> (apologies for the formatting):CURVEPOLYGON (COMPOUNDCURVE (CIRCULARSTRING
> 433449.62, 85320.0 433442.34), CIRCULARSTRING (85320.0 433442.34, 85318.48
> 433441.52, 85317.85 433439.94), (85317.85 433439.94, 85323.26 433407.01),
> CIRCULARSTRING (85323.26 433407.01, 85324.24 433405.814, 85325.76
> 433405.24), (85325.76 433405.24, 85371.68 433412.51), CIRCULARSTRING
> (85371.68 433412.51, 85373.66 433413.74, 85374.28 433415.25), (85374.28
> 433415.25, 85369.63 433446.48)), CIRCULARSTRING (85361.39 433438.49,
> 85365.44 433434.44, 85361.39 433430.39, 85357.34 433434.44, 85361.39
> 433438.49), CIRCULARSTRING (85327.69 433426.1, 85330.18 433423.61, 85327.69
> 433421.12, 85325.2 433423.61, 85327.69 433426.1))CURVEPOLYGON
> (COMPOUNDCURVE (CIRCULARSTRING (85320.0 433442.34, 85318.48 433441.52,
> 433415.25, 85369.63 433446.48), CIRCULARSTRING (85369.63 433446.48,
> 85368.99 433448.54, 85366.08 433449.62), (85366.08 433449.62, 85320.0
> 433442.34)), CIRCULARSTRING (85357.34 433434.44, 85361.39 433438.49,
> 85365.44 433434.44, 85361.39 433430.39, 85357.34 433434.44), CIRCULARSTRING
> (85327.69 433426.1, 85330.18 433423.61, 85327.69 433421.12, 85325.2
> 433423.61, 85327.69 433426.1))The differing directions of rings I can solve
> with OGRCompoundCurve::isClockwise and OGRCompoundCurve::reversePoints to
> ensure consistent ring directions before comparing.The differing order of
> inner rings is solvable by finding matching rings. This is O(N^2), but N is
> small enough in practice to be acceptable.This leaves me with the problem
> of comparing rings that have different start points. My first thought was
> to ask how to change the start point of a closed curve (ring), since I
> cannot find anything about this in the documentation. However that is not a
> solution, since you cannot change the start point to any other point on the
> ring. For example changing the start point to be the mid-point of an arc
> (circular string) would make the geometry invalid.I could iterate the
> points of the closed curve/ring, but I would also have to know how each
> point is connected to the previous/next point (linear, curve). I do not
> know if this information is available, searching the documentation gave me
> no result.So the question is: how can I compare closed curves (rings) that
> have different start points?Thank you for your help.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250825/a3ad1488/attachment.htm>
