[gdal-dev] Unwanted geometry dump in ogrinfo sql
Jan Heckman
jan.heckman at gmail.com
Thu Dec 4 04:35:15 PST 2025
Dear list,
The following command also outputs geometry:
*ogrinfo -sql "select bu_code from buurt_minimaal limit 1"
buurt_minimaal.dbf*
Obviously, there is a buurt_minimaal.shp as well, see this link
<https://www.dropbox.com/scl/fi/0ui1n5bzwigcd80m8nnhk/buurt_minimaal.zip?rlkey=ojhd5qqtf028sgmjduk0v3ldf&dl=0>
The gdal version used is a bit old: GDAL 3.5.3.
- should I do different to avoid geo dumps?
- (if not,) will updating gdal help me avoid this behavior?
Jan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251204/b11eb856/attachment.htm>
