[gdal-dev] Preventing symbol export in custom GDAL build
Kai Pastor, DG0YT dg0yt at darc.de
Fri Dec 12 00:03:21 PST 2025
Thanks for confirming that libcurl is not causing problems here.
libspatialite does have minor issues.
- It always builds with dllexport but never applies dllimport.
- The controlling macro is named DLL_EXPORT which is not specific to the
package. Reverse dependencies following the same idea will turn on
dllexport when they include libspatialite headers.
I am testing libspatialite modifications now in
https://github.com/microsoft/vcpkg/pull/48834. MSVC isn't a local
platform for me, and I rarely deal with nmake since GDAL moved to CMake.
So vcpkg CI building reverse dependencies is my only indicator of
success. External testing welcome.
Kai
Am 12.12.25 um 00:18 schrieb David Klaus:
> All,
> Using a def file to obfuscate the symbol names proved to be a bust. I
> was able to create obfuscated names, but that didn't remove the
> original symbols from the export table. In the end, as many have
> commented, the only way I could remove the spatialite symbols from the
> export table was to patch the spatialite files as seen in my
> custom-portfile folder.
> As far as the libcurl export conflicts, this turned out to be a red
> herring. The conflicting symbol was __NULL_IMPORT_DESCRIPTOR. After a
> lot of searching I realized that a dependency of the project I was
> building also included my custom gdal library. To resolve this issue,
> I simply removed gdal from one of my libraries. This resolved all the
> conflicts I know about.
> If anyone has any further questions or comments, please let me know,
> On Thu, Dec 11, 2025 at 9:01 AM David Klaus <dklaus at carlsonsw.com> wrote:
>     Kai,
>     I am still working on this issue which is why I haven't updated
>     the thread with a solution. I do not intend to keep the solution
>     private.
>     The libspatialite portfile I provided contains a custom patch. I
>     can confirm that this patch prevents export of the libspatialite
>     symbols that caused conflict in my previous build. I have not
>     attempted something similar for libcurl. As I mentioned in my
>     original email, I don't particularly like this solution.
>     Yesterday I tried to patch in def files to the GDAL build. I was
>     hoping that, by removing the libspatialite symbols from the def
>     files export, I would be able to prevent export of these symbols.
>     Unfortunately, this didn't work. Now, I am currently investigating
>     using def files to rename the conflicting libspatialite symbols on
>     export. Hopefully I have more information on this today though it
>     may take longer,
>     On Thu, Dec 11, 2025 at 3:43 AM Kai Pastor, DG0YT <dg0yt at darc.de>
>     wrote:
>         The proper fix is modifying libspatialite IMO.
>         Please confirm if there is an issue with libcurl.
>         I do not like to see uncertainty being made public and fixes
>         being made private.
>         Kai
>         Am 10.12.25 um 20:10 schrieb David Klaus:
>>         All,
>>         Thank you for the suggestions. And to clarify: yes this is an
>>         MSVC build so -fvisibility=hidden is not an option. I am
>>         currently investigating adding a def file to curate the
>>         symbols exported by the gdal dll. I removed the decorated
>>         symbols and built. The resulting dll still reports the
>>         decorated symbols, but I'm hopeful that this is expected
>>         behavior. I'm going to attempt to remove the libspatialite
>>         symbols from the def file and rebuild,
>>         On Wed, Dec 10, 2025 at 1:06 PM Kai Pastor, DG0YT via
>>         gdal-dev <gdal-dev at lists.osgeo.org> wrote:
>>             In vcpkg, x64-windows means MSVC.
>>             And even in the visibility world, you can find libs that
>>             get it wrong when the attention is exclusively on shared
>>             libs.
>>             (Studying the proposed libspatialite patch, I believe I
>>             spotted different defaults for visibility in different
>>             chunks. Needs more investigation...)
>>             Am 10.12.25 um 19:02 schrieb Andrew Bell:
>>>             On Wed, Dec 10, 2025 at 12:55 PM Kai Pastor, DG0YT via
>>>                 Am 10.12.25 um 17:09 schrieb Andrew Bell via gdal-dev:
>>>>                 Hi,
>>>>                 All symbols that aren't specifically exported
>>>>                 should be hidden if when you build the flag
>>>>                 "-fvisibility=hidden" is set. See
>>>>                 cmake/helpers/configure.cmake.
>>>                 I don't think this will help with MSVC and its
>>>                 dllexport declarations.
>>>             I don't know that this is MSVC. I thought it was a GCC
>>>             build on Windows, but regardless, things are essentially
>>>             the same (on Windows you *must* export all the symbols
>>>             you want visible). I don't know spatialite, but there
>>>             should be some sort of DLL marker (like CPL_DLL in GDAL)
>>>             that can be turned off when building a static library
>>>             that you then link into GDAL.
>>>             This may be helpful:
>>>             https://gcc.gnu.org/wiki/Visibility
>>>             Andrew Bell
>>>             andrew.bell.ia at gmail.com
>>             _______________________________________________
>>             gdal-dev mailing list
>>             https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>         David Klaus
>>         Carlson Software
>>         *Disclaimer*
>>         The information contained in this communication from the
>>         sender is confidential. It is intended solely for use by the
>>         recipient and others authorized to receive it. If you are not
>>         the recipient, you are hereby notified that any disclosure,
>>         copying, distribution or taking action in relation of the
>>         contents of this information is strictly prohibited and may
>>         be unlawful.
>     David Klaus
>     Carlson Software
> David Klaus
> Carlson Software
> *Disclaimer*
> The information contained in this communication from the sender is
> confidential. It is intended solely for use by the recipient and
> others authorized to receive it. If you are not the recipient, you are
> hereby notified that any disclosure, copying, distribution or taking
> action in relation of the contents of this information is strictly
> prohibited and may be unlawful.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251212/54b37304/attachment.htm>
