[gdal-dev] vrt inverse RPC warping
Even Rouault
even.rouault at spatialys.com
Tue Dec 16 10:54:31 PST 2025
Hi Thomas,
(just seeing your message from the archive in
https://lists.osgeo.org/pipermail/gdal-dev/2025-December/061216.html.
There are issues with email delivering since last week with
@lists.osgeo.org affecting a number of people)
I believe you can do what you want, but that will require some manual
VRT editing (that could be automated in some script)
You need to first create a warped VRT from your raster, that you will
use to copy/paste/update another warped VRT:
gdalwarp -r cubic -rpc raster.tif raster_rpc_warped.vrt
Then copy it into a dem_inverse_rpc_warped.vrt doing the following edits.
e.g in autotest we have
gdalwarp -r cubic -rpc autotest/alg/data/test_rpc_with_gt_bug_2460.tif
in.vrt
the resulting in.vrt is the following. I've annoted the places that need
to be modified to adapt it for your use case
<VRTDataset rasterXSize="281" rasterYSize="227" subClass="VRTWarpedDataset">
<SRS dataAxisToSRSAxisMapping="2,1">GEOGCS["WGS
84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AXIS["Latitude",NORTH],AXIS["Longitude",EAST],AUTHORITY["EPSG","4326"]]</SRS>
<--- to be removed -->
<GeoTransform> -1.1499575331273579e+02, 3.6616932415051353e-06,
0.0000000000000000e+00, 3.6190393017469262e+01, 0.0000000000000000e+00,
-3.6616932415051353e-06</GeoTransform>
<VRTRasterBand dataType="Byte" band="1"
subClass="VRTWarpedRasterBand"> <!--- update with your actual data
type -->
<ColorInterp>Gray</ColorInterp>
</VRTRasterBand>
<BlockXSize>281</BlockXSize>
<BlockYSize>128</BlockYSize>
<GDALWarpOptions>
<WarpMemoryLimit>6.71089e+07</WarpMemoryLimit>
<ResampleAlg>Cubic</ResampleAlg>
<WorkingDataType>Byte</WorkingDataType> <!--- update with your
actual data type -->
<Option name="INIT_DEST">0</Option>
<Option name="SOURCE_EXTRA">5</Option>
<Option name="ERROR_OUT_IF_EMPTY_SOURCE_WINDOW">FALSE</Option>
<SourceDataset
relativeToVRT="1">autotest/alg/data/test_rpc_with_gt_bug_2460.tif</SourceDataset>
<-- change here to your DEM
<Transformer>
<ApproxTransformer>
<MaxError>0.125</MaxError>
<BaseTransformer>
<GenImgProjTransformer>
<SrcRPCTransformer> <--- change this to
be DstRPCTransformer
<RPCTransformer>
<Reversed>0</Reversed> <-- you may need to
change that to 1. Not entirely sure ...
<HeightOffset>0</HeightOffset>
<PixErrThreshold>0.1</PixErrThreshold>
<Metadata> <--- to be replaced by what you get in in.vrt
<MDI key="ERR_BIAS">-1</MDI>
<MDI key="ERR_RAND">-1</MDI>
<MDI key="LINE_OFF">128</MDI>
<MDI key="SAMP_OFF">128</MDI>
<MDI key="LAT_OFF">36.1895</MDI>
<MDI key="LONG_OFF">-114.9943</MDI>
<MDI key="HEIGHT_OFF">500</MDI>
<MDI key="LINE_SCALE">128</MDI>
<MDI key="SAMP_SCALE">128</MDI>
<MDI key="LAT_SCALE">0.0015</MDI>
<MDI key="LONG_SCALE">0.0024</MDI>
<MDI key="HEIGHT_SCALE">1000</MDI>
<MDI key="MIN_LONG">-180</MDI>
<MDI key="MIN_LAT">-90</MDI>
<MDI key="MAX_LONG">180</MDI>
<MDI key="MAX_LAT">90</MDI>
<MDI key="LINE_NUM_COEFF">0.0418498012 -0.0149130525
4.03738788 2.6824292 -0.293975583 -0.195230863 0.848327924 0.00111702848
0.231318818 0.463079636 0.104397546 -7.92580025e-05 -0.0109232371
0.073238365 0.0226941745 0.00203306277 0.138240173 0.0147348153
-0.0944158497 0.133690662</MDI>
<MDI key="LINE_DEN_COEFF">0.966071333 -0.0705548972
0.054937412 -0.143504966 -0.00263873607 0.0490624273 -0.0407232374
0.00548420472 0.000493945772 -0.00508963274 0.00200894902 0.000300247695
0.000485633376 -0.00767877615 -0.00041179685 -0.000543960426
0.00619465736 -0.00264921176 -0.00147916846 -0.0158449621</MDI>
<MDI key="SAMP_NUM_COEFF">-0.0740525516 -5.21414237
-0.00982810958 3.93746386 -0.262274148 -1.21406902 0.199674781
0.416705428 -0.000130440488 0.673770884 0.104882676 -0.0562560276
0.0158769672 -0.151393292 0.0156039821 3.67853087e-05 -0.0887577654
-0.100124515 -0.0118096929 0.196201559</MDI>
<MDI key="SAMP_DEN_COEFF">0.965447163 -0.0775609504
0.0482259778 -0.144208596 -0.0030041407 0.0508795964 -0.0371312046
0.0105356006 -0.00287000921 -0.00501789141 0.00201318489 -7.63194545e-05
0.00061804791 -0.00832315087 -0.000327509631 -0.000811519204
0.0055600645 -0.00335719232 -0.000913845686 -0.0155829651</MDI>
</Metadata>
</RPCTransformer>
</SrcRPCTransformer>
<-- you need to change this to SrcGeoTransform with the
actual GeoTransform of your DEM -->
<DstGeoTransform>-114.99575331273579,3.6616932415051353e-06,0,36.190393017469262,0,-3.6616932415051353e-06</DstGeoTransform>
<-- you need to change this to SrcInvGeoTransform with the
actual inverse GeoTransform of your DEM -->
<DstInvGeoTransform>31405075.665340796,273097.69935532642,0,9883513.0718359239,0,-273097.69935532642</DstInvGeoTransform>
</GenImgProjTransformer>
</BaseTransformer>
</ApproxTransformer>
</Transformer>
<BandList>
<BandMapping src="1" dst="1" />
</BandList>
</GDALWarpOptions>
</VRTDataset>
Even
http://www.spatialys.com
