[gdal-dev] Updating requirements to C++20 for GDAL 3.13 ?
Greg Troxel
gdt at lexort.com
Tue Dec 16 15:09:25 PST 2025
Even Rouault via gdal-dev <gdal-dev at lists.osgeo.org> writes:
> 1) updating our requirements to build GDAL to C++20 ?
This basically says that gcc 10 is not good enough, and 11 should be ok
and 12 is actually ok. That seems aggressive to me, unless there's a
compelling need.
> 2) and making use of it in our exported C++ headers ? (thus requiring
> C++ consumers of our API to also be C++20)
What bad thing would happen if we don't do that? Aggressive standards
can be hard to deal with, and I think it is better to be conservative
especially in the exported API, absent a compelling argument.
> Our current situation is C++17 required to build GDAL, and our C++
> exported headers are C++11 compatible (except some newer ones like
> gdalalgorithm_cpp.h, and some bits in )
> We already have 2 (optional) dependencies requiring C++20: Poppler and
> PDFium. The next version of libarrow/libparquet will also require
> C++20. Note that C++20 is currenly only enabled in GDAL in the drivers
> whose dependencies require it.
What problems happen if we don't bump the requirement? As I understand
your description, C++20 is required if a driver that requires it is
enabled, and not otherwise. That doesn't seem like a problem.
