[gdal-dev] COG, DCAP_CREATE and check_doc.py
Even Rouault even.rouault at spatialys.com
Sat Dec 20 04:08:32 PST 2025
Andrew,
Did you rebuild ? and are sure your active GDAL Python bindings are the
ones from this rebuild? check_doc.py does pass on CI and locally for me
Even
Le 20/12/2025 à 12:14, Andrew C Aitchison via gdal-dev a écrit :
> I ran scripts/check_doc.py on git origin/master and got an assert:
>  Traceback (most recent call last):
>   File "/home/werdna/gdal/git/scripts/check_doc.py", line 80, in <module>
>     "supports_create" not in doc_caps
>  AssertionError: Driver COG does not declare DCAP_CREATE but doc does!
> I guess that this is related to commit
>   4289c17f6181f6c091adc04e010edf01f875b7e4
> but should it have been caught by continuous integration ?
http://www.spatialys.com
