[gdal-dev] Preventing symbol export in custom GDAL build
Kai Pastor, DG0YT
dg0yt at darc.de
Fri Dec 26 00:40:02 PST 2025
The vcpkg change was merged. The libspatialite and readosm ports no
longer apply dllexport for static triplets.
Kai
Am 12.12.25 um 14:35 schrieb David Klaus:
> Kai,
> Thank you for that information. In regards to your fix for this issue.
> Are these changes coming to libspatialite in vcpkg in the future?
> On Fri, Dec 12, 2025 at 3:03 AM Kai Pastor, DG0YT <dg0yt at darc.de> wrote:
> Thanks for confirming that libcurl is not causing problems here.
> libspatialite does have minor issues.
> - It always builds with dllexport but never applies dllimport.
> - The controlling macro is named DLL_EXPORT which is not specific
> to the package. Reverse dependencies following the same idea will
> turn on dllexport when they include libspatialite headers.
> I am testing libspatialite modifications now in
> https://github.com/microsoft/vcpkg/pull/48834. MSVC isn't a local
> platform for me, and I rarely deal with nmake since GDAL moved to
> CMake. So vcpkg CI building reverse dependencies is my only
> indicator of success. External testing welcome.
> Kai
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251226/9895efcb/attachment.htm>
