[gdal-dev] gdal parquet and hive partitioning
Even Rouault
even.rouault at spatialys.com
Sun Dec 28 07:48:45 PST 2025
Hi Mike,
the problem is likely two folds:
- "gdal vector partition" doesn't write the "_metadata" file that
contains the schema and the path to the actual .parquet files
- but even if it did, I cannot manage to convince libarrow/libparquet to
not probe all files. Not sure if I'm missing something in the API or if
that's a fundamental limitation of the library. I've filed
https://github.com/apache/arrow/issues/48671 about that. I've
considered implementing a workaround on GDAL side but I couldn't come
with anything.
Your best workaround is to directly access
"/vsis3/bucket/overture/20251217/overture-buildings/country=US"
Even
Le 28/12/2025 à 13:26, Michael Smith via gdal-dev a écrit :
> I know that gdal can write parquet data with hive partitioning using gdal vector partition, but after doing so, can gdal do the partition elimination on reading when a where/attribute is specified on the partition key?
> I was trying to do a pipeline with:
> gdal vector pipeline ! read "/vsis3/bucket/overture/20251217/overture-buildings/” ! filter --bbox -117.486117584442,33.9156194185775,-117.333055544584,33.9745995301481 --where "country='US'" ! write -f parquet /tmp/test1.parquet --progress --overwrite
> but in CPL_DEBUG I see it scanning all the partitions rather than just querying the country=US partition.
> S3: Downloading 0-1605631 (https://bucket.s3.us-east-1.amazonaws.com/overture/20251217/overture-buildings/country%3DAI/data_0.parquet)...
> S3: Got response_code=206
> S3: Downloading 0-16383999 (https://bucket.s3.us-east-1.amazonaws.com/overture/20251217/overture-buildings/country%3DAL/data_2.parquet)...
> S3: Downloading 0-16383999 (https://bucket.s3.us-east-1.amazonaws.com/overture/20251217/overture-buildings/country%3DAL/data_3.parquet)...
> S3: Downloading 16384000-32767999 (https://bucket.s3.us-east-1.amazonaws.com/overture/20251217/overture-buildings/country%3DAL/data_2.parquet)...
> S3: Downloading 16384000-29741378 (https://bucket.s3.us-east-1.amazonaws.com/overture/20251217/overture-buildings/country%3DAL/data_3.parquet)...
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251228/389c87a9/attachment.htm>
