[gdal-dev] CSharp bindings queued for removal (was Re: GDAL CSharp bindings maintainers/contributors listening... ?)
    Momtchil Momtchev
    momtchil at momtchev.com
    Sun Feb  2 07:23:15 PST 2025
clang.jl is a very feature-light pybind11-style wrapper generator. It
does not support C++, objects, inheritance, overloading, type
downcasting and upcasting, iterators, n:m argument mapping, exceptions
and many other advanced features. It even lacks interaction with the
garbage collector relying on the user manually freeing the returned C
data structures. All these features would require extensive manual
wrapping work to implement. This is the major strength of SWIG - because
you can implement those advanced features with minimal amount of work if
you are willing to accept its very steep learning curve.
I don't use Julia, but I can still see that GDAL.jl is far below the
level of the Python bindings which I know quite well. There is a higher
level API built on top of it - ArchGDAL.jl - but it seems to be
completely handwritten.
On 01/02/2025 23:45, Joaquim Manuel Freire Luís wrote:
>   * Surely the 100% handwritten bindings - such as PDAL for C# or GDAL
>     for Node.js or Julia
> Hi,
> Just a small clarification, the Julia bindings are a 100% automatic
> creation and cost very little, when one knows how to do it.
> Joaquim
> *From:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> *On Behalf Of
> *Momtchil Momtchev via gdal-dev
> *Sent:* Saturday, February 1, 2025 10:09 PM
> *To:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] CSharp bindings queued for removal (was Re:
> On 31/01/2025 23:31, Howard Butler via gdal-dev wrote:
>     On Jan 31, 2025, at 8:18 AM, Even Rouault via gdal-dev
>     <gdal-dev at lists.osgeo.org> <mailto:gdal-dev at lists.osgeo.org> wrote:
>     My experience with GDAL informed what we did with PDAL. The first
>     thing was to not use SWIG. Lessons were learned, as they say :)
>     The approach of a single unified language binding generator was in
>     fashion in the 1990s at the same time as using UML to
>     automatically write software. History has shown both of these
>     things to have frustrating consequences.
> In 2025 SWIG still has no alternatives. It is surely dated and it may
> be time to think about a successor project, but currently I am not
> aware of anyone actually working on it.
> Recently there has been a new way to do it, pioneered by Boost and
> made very popular by the pybind11 project. This same approach has been
> copied by embind in emscripten/WASM and I also have my own nobind17
> for Node.js. Even if these are much faster to learn and easier to
> maintain - because they do not require a special and very awkward
> specific language - everything is only C++ - they lack many of the
> advanced features that allow a very large library such as GDAL to have
> a fully native feel  - especially one that has not been designed from
> scratch to be used from a higher-level language.
> Surely the 100% handwritten bindings - such as PDAL for C# or GDAL for
> Node.js or Julia - have their advantages, but the development cost is
> orders of magnitude higher. If I was to start GDAL for Node.js from
> scratch, I was surely going to use SWIG. Both GDAL for Node.js and
> GDAL for Julia use handwritten code because at the time of their
> creation, SWIG did not have good support for those languages. PDAL's
> API is orders of magnitude smaller than GDAL and it has been designed
> I personally think that the future belongs to a project that will use
> the LLVM front-end and produce pybind11-like code, but this project
> does not exist. NativeScript is going in this direction for
> JavaScript, but they too, they lack many of the advanced SWIG features.
> Now, of course, if there is no one to work on GDAL for C#, there is
> nothing to be done. It is unlikely there will ever be onboarding for
> this, as its cost is far too great for something that probably will be
> used only once. I am afraid that there are no real alternatives
> besides SWIG.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250202/cc232f1a/attachment.htm>
