[gdal-dev] no autodetect for ZARR output
Laurențiu Nicola
lnicola at dend.ro
Tue Feb 4 04:24:06 PST 2025
On Tue, Feb 4, 2025, at 13:56, Even Rouault via gdal-dev wrote:
> A PR to add .zarr as an extension for the Zarr driver ? Is it recommended by the Zarr spec (can't find anything) or considered a best practice ? This wasn't my impression, although that would certainly be desirable.
Their quickstart <https://zarr.readthedocs.io/en/stable/quickstart.html> uses .zarr as the extension and the v3 spec <https://zarr-specs.readthedocs.io/en/latest/v3/core/v3.0.html> says:
> When storing a Zarr hierarchy in a filesystem-like store (e.g. the local filesystem or S3) as a sub-directory, it is recommended that the sub-directory name ends with `.zarr` to indicate the start of a hierarchy to users.
Laurentiu
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250204/15a29075/attachment.htm>
